Ford WRC.. how do they get away with it ??
Old Dec 28, 2008 | 10:07 AM
pee vee's Avatar
pee vee
Default Ford WRC.. how do they get away with it ??
just wondering, the Focus WRC cars, (and ive only noticed it on the fords)
when they are rallying, everything is SO hot that even the inside of the exhaust tail pipe is glowing pretty much all the time...
so how do they get away with it running so hard and SO hot, even that far back in the exhaust system, and not have melted anything in the engine??
Old Dec 28, 2008 | 10:14 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Because the heat is in the exhaust, not the engine.. the ALS causes that, mainly.. the exhaust isn't made from stainless either, usually inconel or titanium, which may transfer heat better than steel alloy.
Old Dec 28, 2008 | 10:26 AM
Farmer Giles's Avatar
Farmer Giles
because they spend hundreds of thousands of pounds developing everything to work at those levels.
That's why high level motorsport costs so much.
Old Dec 28, 2008 | 10:41 AM
richard_syko's Avatar
richard_syko
There is a catalyst in the tail pipe, as unburn fuel goes through it burns and glows. Its not all that hot,.
http://www.rallysportmag.com.au/home...Exhaust300.jpg
Old Dec 28, 2008 | 10:46 AM
Ginge !'s Avatar
Ginge !
just finding my feet
its a rear light like in F1,,,,, they are so smart them F1 boys that they think of everything in there designs
Old Dec 28, 2008 | 01:07 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
as said above,its the catalitic converter you can see glowing,not the whole exhaust,and the exhaust is coated so that almost all the heat comes out of the tail pipe.the tunnel where it travels down is also heatshielded to protect the body.
Old Dec 28, 2008 | 08:15 PM
pee vee's Avatar
pee vee
cool, thanks!
Old Dec 28, 2008 | 08:23 PM
This might sound silly but i never thought they would have catalist converters on rally cars.
Old Dec 28, 2008 | 08:24 PM
i love anti lag on cars too.
Old Dec 28, 2008 | 08:58 PM
JHS's Avatar
JHS
Why wouldnt they? They have to be road legal...
Old Dec 28, 2008 | 09:23 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
and the first catalitic rally car was ..................
4x4 sierra cosworth driven by a bird called aitkin walker, and she could handle a cozzie let me tell you
Old Dec 28, 2008 | 09:33 PM
Micky The Finn
Former Sponsor
celica gt 4.
Old Dec 28, 2008 | 10:17 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
Tim you sure ???
i remember the ads and it was the rac rally from chester in 92
how the bleeding ell do you go from your old user name to mickey the finn ??
Old Dec 28, 2008 | 10:40 PM
richm's Avatar
richm
interesting that they have Cat's at the back, anyone got any links to more info on this?
I found a pic:
Old Dec 28, 2008 | 10:41 PM
Micky The Finn
Former Sponsor
Tim you sure ???
cats were used in 1991 though.
as for the username,your the one bloke on here i thought would click straight away,infact i thought of you as i typed it!!
Old Dec 29, 2008 | 05:12 AM
Mad Matt's Avatar
Mad Matt
Rally nut
The put the cat at the back because it is less restrictive for the engine than putting it at the front.
Old Dec 29, 2008 | 09:31 AM
richm's Avatar
richm
I'm not sure I follow how it would be, but thats interesting if it is so..
We have to run with catalysts in our saloon race series at castle combe in 2009 so may be worth considering this
We have a 340bhp 1.8T Audi TT and for the odd trackdays are forced to run extra silencing which we do in the form of a tailpipe muffler as it is easy to fit and remove -
http://www.merlinmotorsport.co.uk/p1...duct_info.html
we have a 3" exhaust and this muffler is approx 2" clear I/D and the 8" long - this makes a distinct reduction in power delivery, so I'm interested to know how much effect a Cat would have, even a 100CSI one. If there is benefit in fitting it at the back then that's what I'll try.
Old Dec 29, 2008 | 09:34 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
the cat is as far away from the heat source to prevent it from melting
Old Dec 29, 2008 | 09:46 AM
richm's Avatar
richm
Tony, further to my previous post - are we likely to run a realistic risk of melting the cat in the TT if fitted in a more conventional position, bearing in mind it's being subjected to race use with no regard to AFR that the cat wants to see obviously (11.5-11.8 afr).. ?
Damn thing is only there for the benefit of MSA lip service to the tree huggers, so need to minimise the impact it has on the engine.
Old Dec 29, 2008 | 09:49 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
richm- you put a thermocouple just before the cat and map it rich enough to not melt it
Old Dec 29, 2008 | 09:58 AM
richm's Avatar
richm
lol, will block it up with soot if I go much richer - 11.5afr mostly now.
Old Dec 29, 2008 | 10:01 AM
doctor stavros's Avatar
doctor stavros
AMG C32
Old Dec 29, 2008 | 10:06 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
That's pretty tame for a cat car. A lot of production cat cars run in the 10's at WOT.
Old Dec 29, 2008 | 10:13 AM
richm's Avatar
richm
True - my skoda is high tens at peak rpm WOT.
OK, but I don't WANT to run much lower than 11's lol especially if it's only for the bloody CAT's benefit
Old Dec 29, 2008 | 12:34 PM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
I never knew they put the cats so far back!
And ive wondered before why the focus exhaust was always glowing red hot. Now i know.
Old Dec 29, 2008 | 02:17 PM
Steven_RW's Avatar
Steven_RW
Interesting:
So on a production car they put the cat as far forward as possible (in the down pipe on some cars?) and I believe this is to get the heat to the cat as soon as possible (as a cat needs to warm up to work) whereas on a Rally car they put it as far back as possible to stop it from melting due to their extremely high exhaust temps? Does an anti lag car really have that much higher temps in the exhaust? Would be interested to know how many extra degrees we are talking.
One last thought, I recall being told that an exhaust pipe needs to be larger, closer to the engine as the volume of the gas (due to it being at its hottest) closer to the engine is higher, and as it travels up the exhaust it cools and thus the volume of gas reduces so the bore of the exhaust doesn't necessarily need to be as big. So this would would hint towards a cat (being a restriction) being better placed towards the back of the exhaust as it will create less of a restriction at that stage?
On that note, I was never happy when I was told I had to keep cats on my M3. It reads the gas before and after the cat and goes into a limp home style mode if there is not any difference. So it is either expensive "race" cats or a new style ECU that doesn't read before and after, or some adaption to my current ECU that means it no longer cares (no one seems to be able to do that yet).
RW
RW
Old Dec 29, 2008 | 02:24 PM
Aaroncast's Avatar
Aaroncast
Smile
WHY NOT?????
Old Dec 29, 2008 | 02:28 PM
Aaroncast's Avatar
Aaroncast
Talking
Originally Posted by doctor stavros
---------is it from a moggy!minor-------------
Old Dec 29, 2008 | 02:31 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
aww i think of you too mick er i mean mr finn
A Mickey Finn
Meaning
A sedative (or sometimes in the US a purgative) drug surreptitiously slipped into someone's drink.
Origin
A 'Mickey Finn', which is sometimes called just a 'Mickey' is supposed to be named after a character from 19th century Chicago - 'Mickey Finn', of course. Finn was the keeper of Chicago's Lone Star Saloon in the late 19th and early 20th century. He was alleged to have drugged and robbed his customers. There are a couple of US newspaper references from December 1903 that allude to this
Old Dec 29, 2008 | 02:40 PM
Aaroncast's Avatar
Aaroncast
--------ive got an escort cosworth 96 plate- no cat!! Taken of when purchased----dont need it -----never will!!!!!!!!
The belief that you will fail an mot without it is crap!!!!!
The mot tester can alter the figures!!!
Climate change!! Not from the uk it aint!!-your all brain washed into believing it!!!-like bloody sheep bah-bah-we contribute f----------all to global warming-------------
Old Dec 29, 2008 | 02:47 PM
Well i didnt know They had to be road legal i dont follow rallying much sorry.
Old Dec 29, 2008 | 05:13 PM
krypton's Avatar
krypton
Originally Posted by Steven_RW
Interesting:
RW
RW
Mite be a stupid idea but I know on some french cars like citreon c2s when fitting a 4 branch manifold to them it does away with the cat and you can get a sleeve that goes over the 1st probe and you use the 2nd one. Your ecu will be more complicated so maybe not be able to do something like this
Subaru wrc ran with the cats at the back aswell but not as big as the focus looked just like a standard back box
Old Dec 29, 2008 | 08:56 PM
Ginge !'s Avatar
Ginge !
that is the real reason i would belive, the heat of antilag would melt the bricks if on the downpipe
Old Dec 30, 2008 | 06:47 AM
Micky The Finn
Former Sponsor
a 1996 car with no cat fitted will no longer be type aproved and will not pass an mot.
Old Dec 30, 2008 | 06:49 AM
Nash_mr2's Avatar
Nash_mr2
the red glowing tailpipe isnt heat....it's a Halfords LED Glowing Tailpipe they have to use it to keep the sponsors happy, it's wired to the fog lights.
Billy_RS
16
Oct 11, 2025 09:41 PM
Ford Focus ST Parts for Sale
Aug 28, 2015 01:32 PM
borboyous
Aug 22, 2015 11:17 AM
RockinRein
Aug 19, 2015 07:08 PM
