will these fit?
Old Dec 25, 2008 | 07:49 AM
rst-s2's Avatar
rst-s2
Red 90 Spec s2 RS Turbo
Default will these fit?
4 x 108 offset is et15 they are 15 x 6.5 size alloys for a series 2 rs turbo?
oh and merry xmas!
Old Dec 25, 2008 | 07:59 AM
gus's Avatar
gus
i cant remember what our pcd is
but the et 15 will stick the wheel out a bit
Old Dec 25, 2008 | 08:13 AM
rst-s2's Avatar
rst-s2
think 4x108 is the pcd it was just the 15 et bit i wasent sure about
Old Dec 25, 2008 | 10:30 AM
Karlos G's Avatar
Karlos G
Balls Deep!
PCD is 108 on escorts
Old Dec 25, 2008 | 10:52 AM
addiction's Avatar
addiction
the pcd is correct and pretty much the same on all 4 stud Ford hubs but with a 15et offset they will stick out a fair bit!!
Old Dec 25, 2008 | 10:55 AM
Ade's Avatar
Ade
Fast Ford snapper
Sounds like Pug wheels, the centre bore will probably be larger too..... not a show stopper, but will need spiggot rings if you want them located properly.
Also with that offset they will be sittig out further than normal, can look really good or just be hassle with arch rubbing depending how you deal with it.
Old Dec 25, 2008 | 03:15 PM
rst-s2's Avatar
rst-s2
whats spiggot rings? been told there ford wheels so should be fine, there only 15'' so should be good with arches
Old Dec 25, 2008 | 03:42 PM
Ade's Avatar
Ade
Fast Ford snapper
Plastic inserts that resize the centre hole of the wheel to the correct size for the hub.
Very unusual if they are Ford wheels being ET15. Only ones I can think of are Escort Cossie rims.
What wheels are they exactly?
Old Dec 25, 2008 | 10:47 PM
marky_g's Avatar
marky_g
Fleet Manager
et15 15's should be fine my 16 et15 wheels only catch slightly on the rear but have the wrong tyres
Kyle Langford
27
Aug 5, 2019 07:54 PM
ekjim
Aug 27, 2015 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
