when it get hot it..........
Old Dec 24, 2008 | 08:44 PM
s2messa's Avatar
s2messa
Default when it get hot it..........
when my escort rst get up to temp and you turn it off, then try to crank it over. it turns over really slowly like its got a flat battery. Does any body have any idea what this would be? thanks
Old Dec 24, 2008 | 08:48 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
i had this with my xr2, changed starter, battery, earths and power lead to the starter, and wrapped the starter to protect it from the heat, nothing fixed it, so a zetec went in and its doing it again.
im trying a battery with a higher cranking amps rating, but i cant think of anything that i havnt tried
if you sort it let me know!
Old Dec 24, 2008 | 08:51 PM
s2messa's Avatar
s2messa
tried some of that stuff all ready as well . ok will do thanks any way..
Old Dec 24, 2008 | 08:59 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
im sure someone must have sorted it once before, just not us
if you have a bigger battery lying about you could try that, im trying to find a mate with a spare i can use for a few days but no joy yet.
Old Dec 24, 2008 | 09:03 PM
s2messa's Avatar
s2messa
some one did say to me once to try a diesel battery off a escort van , but never got around to trying it ..
Old Dec 24, 2008 | 09:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Heat from the turbo and manifold kills starter motors on Rs's, there is suposed to be a heatshield to protect it but most lost them long ago!
Heat wrapping your manifold can help or sourcing another heat shield.
Old Dec 24, 2008 | 09:19 PM
s2messa's Avatar
s2messa
yea i was told that by a mate from ford and had new starter motor and heat wrapped down pipe thanks any way..
Old Dec 24, 2008 | 10:49 PM
mitchrst's Avatar
mitchrst
1981
Put a diesel starter motor on it, It will fly round.
Old Dec 25, 2008 | 09:26 AM
s2messa's Avatar
s2messa
will it defo fit cuz some one said there too long .
Old Dec 25, 2008 | 09:37 AM
grotty's Avatar
grotty
A diesel started motor fixed mine. It sounded as if it was spining too fast lol
Old Dec 25, 2008 | 09:38 AM
obrutsr09's Avatar
obrutsr09
Just heat wrap down pipe
Old Dec 25, 2008 | 10:54 AM
addiction's Avatar
addiction
the proper turbo heatshield is still available from Ford and usually fixes the problem!!
Old Dec 26, 2008 | 01:18 AM
Robs Frst's Avatar
Robs Frst
As above the heatshield is still available from Ford. Get 1 it makes a big difference. to this problem.
Old Dec 26, 2008 | 01:31 AM
Šhatter Box's Avatar
Šhatter Box
you need to et the 1.4 cranking amp they work a treat.
Old Dec 28, 2008 | 10:18 AM
coswurv's Avatar
coswurv
100% diesel starter is required 3 escort turbos all with zvh conversions required diesel starters. never had a problem on any 3 of them since.
Old Dec 28, 2008 | 02:43 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
had this prob on 2 of my s2s,and cured it wiv diesel starter motor
Old Dec 28, 2008 | 07:46 PM
XR2's Avatar
XR2
Had the same problem on my XR2 when we moved the battery to the other side. We forgot the mass connector to the starter motor. The cold engine works fine as a mass connector, but when it gets hot, its electrical resistance rises. With a warm engine the starter refused to do his work, but when the car was pushed, the engine started without any problems. Made a NEW mass connector and everything was fine again. Although it sure is a good idea to take care of the heat problems a turbo makes...
Old Dec 28, 2008 | 07:58 PM
FIESTA CHRIS H's Avatar
FIESTA CHRIS H
my step dad has the same problem on his orion 1.6 injection as soon as it gets warm it cranks over slowly. Could a diesel starter solve his problem as his insnt a turbo powered cvh?
Old Dec 29, 2008 | 02:21 AM
blk-Mk5-zs's Avatar
blk-Mk5-zs
what year and engine size diesel?
ill have to try it with my zetec that has a s1 rst gearbox if it will fit...
thanks
Old Dec 30, 2008 | 10:11 PM
johnnysash's Avatar
johnnysash
any ideas on how much?
Old Dec 31, 2008 | 07:58 AM
Ebonycossie4x4's Avatar
Ebonycossie4x4
i would also like to kno what diesel one to fit as if i keep mine this sounds like an excellent mod.
Fiddy
21
Sep 29, 2015 06:10 PM
PeterLucas
Sep 21, 2015 11:36 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
