NEW AEROMOTIVE fuel filter & NEW TURBOSMART BOV ---- SOLD
Old Dec 16, 2008 | 11:14 PM
Stuart.W's Avatar
Stuart.W
Default NEW AEROMOTIVE fuel filter & NEW TURBOSMART BOV ---- SOLD
BRAND NEW 12302 AEROMOTIVE PRO SERIES FUEL FILTER, BOXED.
http://www.aeromotiveinc.com/products.php?prod=181
"Pro Series Fuel Filter featuring 100 micron cleanable, stainless steel element, massive -12 AN O-ring boss inlet and outlet ports, and the Pro Series electroless nickel-silver finish. 7" long X 2.5" diameter. Flows 2,000 lb/hr with a pressure drop of less than 0.15 PSI! Perfect for inlet protection of expensive, high flow racing fuel pumps."
This is a pre-pump filter to be mounted between the fuel tank & pump.
UK price of £154.00:http://www.turbomatrix.co.uk/product...l-fuel-filters
& £151.61:http://www.jdmperformance.co.uk/search.php?q=12302
SOLD
BRAND NEW TURBOSMART 38mm PLUMBACK (RECIRCULATING - PLUMB BACK) DUMP VALVE (BLOW OFF VALVE - BOV).
ONE OF THE BEST DUMP VALVES ON THE MARKET, GENUINE TURBOSMART PRODUCT, UN-USED, 100% PEREFCT & BOXED, £195 UK RRP!
INCLUDES 38MM EXHAUST PORT, 38mm STAINLESS STEEL INLET WELD FLANGE AND OPTIONAL 38mm ALUMINIUM INLET HOSE / WELD CONNECTOR TUBE & HOSE BUNG.
CAN BE USED AS RE-CIRCULATING OR OPEN TO AIR VENTING.
SOLD
Old Jan 11, 2009 | 10:49 AM
Stuart.W's Avatar
Stuart.W
Both now sold
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
cossie09
Sep 14, 2015 04:21 PM
gavt123
Sep 5, 2015 10:03 AM
jonjg
Sep 1, 2015 03:46 PM
