knocking noise any ideas
Old Dec 13, 2008 | 09:46 PM
twinks's Avatar
twinks
Talking knocking noise any ideas
finally took escort out of its hibernation for a wee blast round the block only to discover its making a knocking noise from the front drivers side footwell ,gets worse when go left .. cant keep going round roundabouts all day ...seems to feel as though there is something banging on floor behind pedals..had a quick look underneath but nothing seems to be loose or hanging down... any ideas please..
thanks
Old Dec 13, 2008 | 11:02 PM
L3 COS's Avatar
L3 COS
check the exhaust hasnt come loose on the turbo,had it plenty times before then it catches the floor. (by the front prop shaft)
Old Dec 13, 2008 | 11:21 PM
paul16v's Avatar
paul16v
Monte 087
Does it make a noise when you first take up drive? min had a similar noise and it was the front diff.
Old Dec 14, 2008 | 03:08 PM
dave cos4x4's Avatar
dave cos4x4
most probably the tri bearing at the end of the driveshaft.
Old Dec 14, 2008 | 03:13 PM
ECOS95's Avatar
ECOS95
Sounds like the OS outer CV joint. Turning left loads that joint so you get the noise.
Could also be the outer TCA bush.
Old Dec 15, 2008 | 10:28 AM
twinks's Avatar
twinks
Thanks all, I will be busy tonight out in garage having a check on the items you all identified
Old Dec 16, 2008 | 03:32 AM
c0ss1e9i6's Avatar
c0ss1e9i6
Franco
I've had this many times and its always worse in cold weather!
Old Dec 16, 2008 | 05:56 PM
stookay's Avatar
stookay
alright mate , ive had similar problem after fitting new mongoose , caught a speed bump and it moved exhaust slightly , it was hitting the knuckle joint on front propshaft , had to loosen exhaust bolts on turbo to re align exhaust .
best regards
stookay
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
Flateric_2002
Sep 15, 2015 08:41 AM
rogerxr3i
Sep 13, 2015 06:56 PM
BRAM
Sep 8, 2015 07:11 AM
rsturbo27
Sep 5, 2015 05:08 PM
