S2 gearbox question
Old Dec 13, 2008 | 08:43 PM
hunterlaar's Avatar
hunterlaar
Default S2 gearbox question
Hi, can any of you S2 guys help me, my gearbox died on me! Oil everywhere and whining in 1st and 2nd gear, so I have just taken it out, bigger job than I thought!
Does anyone know what code on the outside of the gearbox should be? so I can determine what the box is before I start taking it to bits, can you tell between an s2 box and a normal escort or diesel box without the limited slip dif in it?
First time I have taken a gearbox out, but probably not the last with owning a ford! lol
Old Dec 13, 2008 | 08:59 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
where the shaft goes,if u got a bar going arcross it its a std box,if u aint its a turbo box!
Old Dec 14, 2008 | 10:21 AM
hunterlaar's Avatar
hunterlaar
I will have to go have a look as I dont know what bar you mean, hopefully mine hasnt been changed and is still an rst box!
Old Dec 14, 2008 | 10:23 AM
adam.d's Avatar
adam.d
Look thru where the driveshafts fit in mate
Old Dec 14, 2008 | 10:27 AM
hunterlaar's Avatar
hunterlaar
just looked through where the shafts go....and theres no bar, thanks for the help guys, now the work begins!!
Old Dec 14, 2008 | 12:09 PM
B1G_RST's Avatar
B1G_RST
ive my box out just now, i can see straight through it, thus mines aint got a lsd correct ?
Old Dec 14, 2008 | 01:37 PM
sm's Avatar
sm
if you can see straight through ie no bar visable then you have a lsd box
Old Dec 14, 2008 | 02:16 PM
Karlos G's Avatar
Karlos G
Balls Deep!
The bar through the middle of the right hand diff will NOT be there if it's a LSD, the one pictured is a NON LSD.
So if you can see the bar its a NON LSD box.
Old Dec 14, 2008 | 02:26 PM
RSTurboSI's Avatar
RSTurboSI
LSD looks like this
Old Dec 14, 2008 | 02:27 PM
RSTurboSI's Avatar
RSTurboSI
if you look through the driveshaft hole and its blank with just a small hole in the middle (like yours) its an lsd diff.
Old Dec 14, 2008 | 03:49 PM
hunterlaar's Avatar
hunterlaar
Thanks for all the pics guys, been a great help,
Just wanted to check before the rebuild, if it was a non lsd gearbox I wouldnt start rebuilding it!
Cheers again!!
Old Dec 14, 2008 | 07:24 PM
B1G_RST's Avatar
B1G_RST
yess ive got a lsd ha
Old Dec 14, 2008 | 08:06 PM
hunterlaar's Avatar
hunterlaar
Thats 2 people happy then! lol
Old Dec 14, 2008 | 09:09 PM
blueskies85's Avatar
blueskies85
wouldn't have been a bad thing if you'd have had a diesel box mate as the power is progressive so there is not really any need for an lsd... i know what you mean though lol lsd's are awesome! Still dont solve torque steer over 40mph though been reading up about the fiesta turbo's and apparently they didnt have one fitted... must be like driving a ferrari on ice Good luck with the rebuild!
Old Dec 14, 2008 | 09:25 PM
hunterlaar's Avatar
hunterlaar
Just glad I have the correct box in it to rebuild now,
cheers mate, just want it rebuilt and back in now, I am missing driving the turbo!
Old Dec 14, 2008 | 09:28 PM
blueskies85
dont blame you one bit mate they are lovely cars, hopefully will have 2 soon... not me being greedy just getting rid of mine after i buy a diff one, I must say how good they are on fuel too... i drive to work off boost and back home on boost and it does around 250 miles to a tank, the price of fuel getting nice and cheap again is nearly costing me as much as my diesel polo cost
Old Dec 15, 2008 | 09:04 AM
Moonie's Avatar
Moonie
Have a look at my rebuild thread....
https://passionford.com/forum/restorations-rebuilds-and-projects/196934-engine-and-gearbox-rebuild-time-update-24-08-a.html
Theres a few pics on there from when i rebuilt my box.
Have you got 5th gear off yet?
Old Dec 15, 2008 | 10:02 AM
hunterlaar's Avatar
hunterlaar
https://passionford.com/forum/showthread.php?t=196934
Cheers for that mate, should be a good help them pics!, I havnt checked on progress yet, I will see tonight, is 5th gear a bugger to get off??
Thanks
Old Dec 15, 2008 | 06:15 PM
Moonie's Avatar
Moonie
Yeh it can be very tight to remove, if its loose then the chances are the inputshaft/gear splines are worn and will require replacing. Once you have 5th gear off then its quite straight forward to strip. Just keep everything in order for when you come to rebiuild
If its tight you should be able to remove it with a decent 2 or 3 leg puller. There is also a proper tool available for removing the gear however i cant find any links to it on the net.
Some more useful links...
http://www.quantums.info/gearbox.htm
http://www.turbosport.co.uk/showthread.php?t=135731
Old Jan 4, 2009 | 10:43 AM
hunterlaar's Avatar
hunterlaar
Thanks for all the comments and help guys.....the gearbox is now rebuilt and back in my s2 and running perfect!!!! bring on the summer shows!
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
