Boost pressure control valve
Old Dec 12, 2008 | 11:44 PM
COLEYST200's Avatar
COLEYST200
Default Boost pressure control valve
hi lads a mate of mime has got to swop out his Boost pressure control valve......amal valve he has a big turbo escort cosworth . the thing is he has a black one on his car and he has just got his hands on 4 new ones 2 black and 2 brown is there any diforenc in them and should any of the ports have a restrickter in them and if so which ones thanks for your help
Old Dec 13, 2008 | 09:19 AM
THE RADMAN's Avatar
THE RADMAN
esc cos ones have 2 stubs and no restrictors so make sure youve got the right ones as ive never seen a brown esc cos one before
Old Dec 13, 2008 | 10:41 AM
Dave Henshall's Avatar
Dave Henshall
also the escos one is not an amal vlave, it works completely different to the sierra ones.
the sierra ones just open at a level that the ecu says when the boost is too high.
the escos lectron valves use pulses from teh ecu to acyually control the boot level ( closed loop boost control) , this is normally only avaliable on P8 ecus, however i have noticed that teh RP labs L8 software now offers this
Old Dec 13, 2008 | 02:06 PM
paul16v's Avatar
paul16v
Monte 087
Old Dec 13, 2008 | 02:57 PM
Dave Henshall
the T piece is important in the setup as it contains the right restrictors for it to work - note in the pic...
Old Dec 13, 2008 | 05:59 PM
COLEYST200's Avatar
COLEYST200
THANKS MATE for your help i will pass this onto my mate
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
routemaster
Sep 7, 2015 05:27 PM
