the easiest way to get side skirts off a s2, HELP NEEDED
Old Feb 17, 2004 | 02:25 PM
Default the easiest way to get side skirts off a s2, HELP NEEDED
hi
i am trying to undo the 4 or so cross head screws that hold the side skirts up .and there solid ,theres no way there comming un-done ,has anyone else had this problem and how did you sort it ,,,ive snapped 3 crowbars so far and i am begging for help .
is it best to just cut the heads of these screws ,rewmove the skirts and them work from there .and try to remove the threads from the inserts ,
or shal i just torch the fookin car and claim of my insurance
regards ,dave
Old Feb 17, 2004 | 03:04 PM
PJay's Avatar
PJay
I used an impact driver for most of mine but 1 had to come off with the dremel drill
Old Feb 17, 2004 | 06:06 PM
Benn 304R's Avatar
Benn 304R
I just drilled em out
Old Feb 17, 2004 | 06:50 PM
depend if u want new sills??
i use a chisel (between kit and sill) and hammer as it takes the head off and doesnt damage the kit, but somethimes they put a hole in the sill,
ur crowbars are crap mate made of chocolate lol
depends on the situation mate, is the car gonna have new sill??, if so the main priorty is keeping the kit nice for refitting
Old Feb 17, 2004 | 07:02 PM
THANKS PPL , i will try the pj way first ,then the drill .im hoping to keep the sills ,although ive found a nice hole at the rear end of sill ,so more weldings needed on that bit ,
thank you all for the advice .
Old Feb 17, 2004 | 09:59 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
Hope you get it sorted mate - I was lucky bought my kit off the original car!
Old Feb 17, 2004 | 10:12 PM
thanks m8
Old Feb 18, 2004 | 06:25 AM
adamS2RST's Avatar
adamS2RST
They are a pain, but not too bad once you done it once, lol fitting it back on is harder good luck
Old Feb 18, 2004 | 07:56 AM
and i thought the refitting would be easy
shim
Old Feb 18, 2004 | 02:14 PM
no probs there ,i drilled the heads off the bolts and carefully chizzled at the rest of the bolt head, pop .the skirts came off a piece of piss .....so the difficult bit is refitting ,,,,,, i will let you know what happens lol
thanks for all the help guys
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
