cossie 2wd and 4x4 engine looms?
Old Dec 4, 2008 | 08:14 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default cossie 2wd and 4x4 engine looms?
other than the tps being wired differently, are there any other differences between the 2?
and with regard to the tps, the one on my car is an active sensors one, only has 2 wires. could this be made to work with a cossie loom?
everything else should be ok.
cheers all.
Old Dec 4, 2008 | 09:24 PM
xr4x4rs's Avatar
xr4x4rs
only other differences is where they connect to main loom, 2wd behind dash, 4wd behind battery
water temp sensor is located in a different position aswell, front of head on 2wd and back of head inlet side on 4wd
Old Dec 4, 2008 | 09:25 PM
silky16v's Avatar
silky16v
Get on That!
4x4 has knock control, temp sender in different location, 4x4 loom is a 2 piece loom
Old Dec 4, 2008 | 09:27 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
ah cheers lads.
it will be going on my zetec turbo, so a few things will need modding. so i guess i need a 2wd loom then to plug straight into the ECU
cheers
big_Rad
Sep 15, 2017 09:36 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Topjoe9
Aug 20, 2015 02:38 PM
muz
Aug 16, 2015 12:57 PM
RsS2daz
Aug 14, 2015 05:26 AM
