RS Turbo Story (with a qeury)
Old Nov 18, 2004 | 06:14 PM
AJC's Avatar
AJC
Default RS Turbo Story (with a qeury)
the other night, just been racing with my mate on back roads
i pulled back onto main road and give it some when the exhaust popped
loudly and engine cut out, it would not start so i left it for 5 mins and
tried it again and it started no problem at all, i have been told this is over
boost, is this true?
and just to add insult to injury my clutch cable snapped just as i got back in the car to go home, gutted, so last night i did the clutch cable
and replaced the distributor oil seal which was leaking like mad, fixed rear window heater and sorted out alternator belt.
so going to go out and slay the toyota starlet turbo again this weekend
when it dry (hopefully)
Old Nov 18, 2004 | 06:40 PM
KSA-Cossie's Avatar
KSA-Cossie
Not overboost m8.
Old Nov 18, 2004 | 06:47 PM
AJC's Avatar
AJC
cheers, i did not think it would be, i will give it a bit to see if any one else
replys
KSA-Cossie's Avatar
KSA-Cossie
No probs m8.
Old Nov 19, 2004 | 03:55 PM
escort frenzy's Avatar
escort frenzy
Try your fuel pump relay and your wiring to your ignition switch. Mine did that and thats what i found. Took me ages to find the problem
Old Nov 19, 2004 | 04:06 PM
AJC's Avatar
AJC
cheers, will have a look this weekend, aint had any trouble with
it since then though, touch wood!!!!!
cheers
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
