opinion please
not really sure what to do i have a s2 which i cant get working for some silly reason i think its coil or somthing...but im fed up and want a cossie i have 2k saved clearly that isnt enough...i think my s2 would be worth alot if it worked properly...soo should i break the s2 and aim for 1500-2k for it...then pump 4k into a cossie.....
.........also do u htink i would e ble to sell most of the car on here.......the shell is a minter how much are they worth?
if you can afford to buy a cossie TWICE then do it . if not id stick with the rst .(cant be that hard to sort and get running good)
granted 4k will get you a fair cossie and as we all know they need working doing especailly if its not been looked after before.
obivously this is my opinion but thats just how i see it . im sure you'll get more responces to this
it only fires on 3 no matter which way the plugs and leads go round ..i found tdc buy the correct way..new fuel lines....new everything part from coil...im fd up and want a cozzie
he put his penis in the exhaust
dan if u got 2k saved up i would just take it to sterte garage like i said mate they will fix it for bugger all money then spend your 2k on whatever you like...
i cant drive it to a garage because no insurense and tax ..im not going to risk any points for the old girl......i have lost intrest big time.....i want a 3dorr saff but i cant even find any...all the nice cossie i find are 5door 4wd
..its hart breaking
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
