8x17 wheels, what about the tyres and arches ?
Old Dec 3, 2008 | 05:19 PM
Mad Matt's Avatar
Mad Matt
Rally nut
Default 8x17 wheels, what about the tyres and arches ?
I want to put 8x17 wheels on my saph, but I'm afraid about the arches. I think they will need some work to cope with the wheels. Also which tyres can I put on them ?
215/45 ZR17
225/45 ZR17
Or any other dimension ? The best would be 225/40 ZR17 but unsure if there is any company doing them.
Old Dec 3, 2008 | 06:09 PM
Nash's Avatar
Nash
Cake lover!
Depends if your car is 2wd or 4x4, also the offset of the wheels.
I run 8x17 RL7s on my saph and only the front archs are rolled. Thats with 215/40/17 on the front and 235/40/17 on the back. You will need to run the same size tyres if your car is 4x4.
Also i am fairly sure 45 profile tyres wont fit on the front unless you are running coilovers, this is because the tyre will hit the spring cups.
Old Dec 3, 2008 | 06:23 PM
Mad Matt's Avatar
Mad Matt
Rally nut
Yes the car is a 4WD and I run bilstein big 50mm group N coilovers at the front and mag group A at the rear.
I'm afraid that with arches rolling I will have to re-paint some parts of the body...
Old Dec 3, 2008 | 06:49 PM
I dont know if my 17s are 8inch wide but ive got 215/40/17s ive got standard shocks and springs on my car and sometimes the front wheels catch on the arches.
Old Dec 3, 2008 | 09:33 PM
Nash's Avatar
Nash
Cake lover!
Shouldnt have to get it painted again if the rolling is done properly. Better to do it than end up with a small dent/crease[Done before i got the car] in the wing like i have from the wheel hitting the arch when on lock.
Old Dec 3, 2008 | 09:39 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
got 8x17 on mine with 225 35 tyres not had any probs
Old Dec 4, 2008 | 09:05 PM
Ridgey's Avatar
Ridgey
Old Dec 5, 2008 | 12:10 AM
pacwest's Avatar
pacwest
Puller of the Wrench
I have AVO coilovers and comp MO et32 on a 235/40 17 on a stock sierra (XR4Ti) body that is not as wide as a cossie body. Front and rear.
Old Dec 5, 2008 | 05:44 AM
Mad Matt's Avatar
Mad Matt
Rally nut
35 would be good for arche clearance, but its just too low, and driving on bump roads won't be nice with hard coilovers. I would prefer 40 or 45. The best will be to see on car I think.
Old Dec 7, 2008 | 08:50 AM
ital_cossie's Avatar
ital_cossie
hello,
i have revolution 17" 8x17 ET33 with 215/40/17 and suspension koni adjustable shocks with eibach low springs.... On the front arches problem... Better fit 17" on saph with coilovers. It's my next step!
Old Dec 7, 2008 | 09:33 AM
Mad Matt's Avatar
Mad Matt
Rally nut
Ok thank you for the feedback !
155lee
Sep 6, 2016 11:10 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Mk5brown
Sep 9, 2015 12:52 PM
Adam Graham
Sep 6, 2015 06:04 AM
3dr cossie
Sep 2, 2015 08:58 PM
