Running/Sparking Problems
i have a 1.8 zetec with bike carbs that have been set up by bogg brothers
when i pull the leads for cylinders 1&2 nothing changes.
whin i pull the leads for 3&4 the engine stalls
there is a spark through 1&2 leads
3&4 plugs are jet black which is usually over fuelling but the carbs have just been set up, could it be anything else?
1&2 plugs are just grey.
the car barely accelerates so im guessing all 4 arnt running properly although theres a spark at every lead
any suggestions?
thanks
any suggestions?
thanks
i was running injection when you saw it, its on bike carbs now using different management. it only has water temp, cps, coil pack, vacuum and rev counter
which im replacing, that might sort the spark on 1&2.
hopefully.
once i get a spark on 1&2 ill be straight back down to bogg brothers as 3&4 plugs are black...
cheers
hopefully.
cheers
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
