2 bar Map sensor
Old Dec 3, 2008 | 06:46 AM
ianbobo's Avatar
ianbobo
oohmamama
Default 2 bar Map sensor
Hi friends,
Is it ok to use a 3 bar map sensor (Magneti APS0501) to replace a faulty 2 bar map sensor (Magneti APS 0203) on a standard sapph cosworth 4x4? Would I alter the engine/ecu behaviour. Turbo model is TB0384.
Apparently APS 0203 has been discontinued. Your help and knowledge is greatly appreciated.
Old Dec 3, 2008 | 06:50 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
No, not without changing chip.
Old Dec 3, 2008 | 03:51 PM
ianbobo's Avatar
ianbobo
oohmamama
many thanks for your quick reply. So its always advantageous to repalce a faulty 2bar map sensor with a 3bar sensor in case upgrading is required in future?
Old Dec 3, 2008 | 04:21 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Dunno, depends if you can get a suitable chip. Might as well just go for a Stage 2/3 conversion (chip/injectors/3bar/optional_t34)..
If you want the car standard, then buy another 2 bar.
Old Dec 3, 2008 | 04:58 PM
ianbobo's Avatar
ianbobo
oohmamama
Yes standard I would like to keep it but the problem is that magneti marelli no longer manufacture 2bar sensor. There are other similar and cheaper 2bar on the market but dont know their reliability. Thats why I asked about the 3bar which is still in production by magneti marelli.
Old Dec 3, 2008 | 05:01 PM
LHD220Turbo's Avatar
LHD220Turbo
Originally Posted by ianbobo
Hi friends,
you cannot change a 2 map sensor with a 3 map bar sensor; it will not work
if you intend to keep the car standard replace the fault map bar sensor with a 2 map bar sensor
if you want more power, as said above; you may as well go for stage 3; which invloves a new chip, new injectors, different turbo (maybe), bigger intercooler etc
Old Dec 3, 2008 | 05:22 PM
ianbobo's Avatar
ianbobo
oohmamama
So, am I right to say that at 10 psi boost a 2bar map sensor sends a signal to the ecu which is different than that from a 3bar map sensor at the same 10 psi of boost? Is this why if I use a 3 bar sensor it will not work? please elaborate. thanks.
Old Dec 3, 2008 | 05:26 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Yes, that's right.
Old Dec 3, 2008 | 07:47 PM
ianbobo's Avatar
ianbobo
oohmamama
thank you all for your advices. great place to share & solve your cosworth problems
Old Dec 3, 2008 | 07:48 PM
LHD220Turbo
- now post up some pics of your cosworth- where are you from?
Old Dec 3, 2008 | 08:23 PM
ianbobo's Avatar
ianbobo
oohmamama
Yes I gladly will. I'm from malta.
Old Dec 3, 2008 | 09:07 PM
ianbobo's Avatar
ianbobo
oohmamama
some pictures of my Cosworth in my album"sapph 4x4"
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
