few problems with my new rst
hi guys im new here and about 2 months ago i purchased my dream car erst.
88 spec
full magnex exhaust
baileys dump valve
pipercross filter
rebuild 26000 ago
i wouldnt no how to tell if the boost has been touch since ive never owned a turbo'd car before. i love the car atm lol but ive got a few things im concernd about and i wondered if you can help
any help would be really appreciated thanks
88 spec
full magnex exhaust
baileys dump valve
pipercross filter
rebuild 26000 ago
- first the car struggles to start when cold and have to pump the pedal but its fine when its warm
- somtimes the car idles at 2000rpm then goes down to normal 10 mins or so
- the other day i was driving around and still after about half hour the temprature guage was still at the bottom shouldnt it be sitting about half way on normal ?
- the main problem was on top end i go into 5th and after about 70ish you hear the turbo spool up and the dump valve starting to woosh abit then it sort of shudders and wont go any further and slows down
does sound like a good set up is what you need mate, then you know everything is spot on - could be fuelling or timing or that so better get the experts to diagnose?
Is your temp guage moving at all? Sender or guage could be faulty but both easy to change
oh and get some pics up
cheers guys yeh the temp gauge does go up to halfway usually but the other night it didnt move at all. yeah im just down the raod from torque of the devil in uxbridge so does anyone know how much they charge for a set up ?
Russ Payne
Sep 25, 2015 08:29 PM
