would these fit??
its the same as fitting 10mm spacers to std s2 alloys.
so basically you will not be able to go low, or if the wheels are wider than 6j then you may not even be able to fit them unless you chop some arch out
i'l give you a rough idea, mines a mk3 xr3i with 7 1/2 x 16's with et 25 and lowered 40mm, needs arches rolled and some camber to avoid wasting the tires and front wings!
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
