zetec turbo
Old Nov 30, 2008 | 11:38 AM
crazycage's Avatar
crazycage
Default zetec turbo
ive got a bigish power zetec turbo highish comp and want to run some nos for the 1/4 mile ,
ive got a won kit with 50hp jets .
my management has the facility(spelling) to pull some ignition out on nos so how much would i need to pull out to be safe ,and wheres the best place to put the jets.
Old Nov 30, 2008 | 11:41 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You wouldn't know how much spark retard you need until you go out and test it. You may not need any at all!
Nozzle placement depends if you're running a single nozzie, or multiple.
Old Nov 30, 2008 | 11:43 AM
crazycage's Avatar
crazycage
is multple not a direct port kit ?
Old Nov 30, 2008 | 11:45 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Yes.. is that what you have? Also you can't have "won" and "nos" at the same time - they're both brand names!
Old Nov 30, 2008 | 11:47 AM
crazycage's Avatar
crazycage
oops, i have a won kit single nozle
Old Nov 30, 2008 | 11:53 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
The nozzle just needs to be upstream of the throttle butterfly really, preferably in a position where as to avoid puddling.
Old Nov 30, 2008 | 11:56 AM
crazycage's Avatar
crazycage
sorry what do you mean upsteam? in the plenum? or in a boost pipe just before the throttle body
Old Nov 30, 2008 | 12:09 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
The latter
Old Dec 16, 2008 | 07:05 PM
crazycage's Avatar
crazycage
ok got round to fitting this kit and im not sure where to put the T for the fuel side of the nos kit ,would just before the fuel rail be a good place .
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
