fuel pump question?
Old Nov 29, 2008 | 12:16 PM
mikey_clough's Avatar
mikey_clough
Default fuel pump question?
hi all, was wondering if i could get some help with my s2. its been a bugger to start for a while now and i think its a fuel pump/relay problem. if i bridge the relay it will start after a bit of cranking, but the fuel pump is making really wierd noises, if i try to rev her she dies almost like the pumps not getting enough fuel to the engine? any ideas. cheers
Old Nov 29, 2008 | 01:06 PM
studabear's Avatar
studabear
check all breather pipes, hoses and connections, also when was the fuel filter last changed?
Old Nov 29, 2008 | 08:30 PM
blueskies85's Avatar
blueskies85
if you have bridged the pink relay on terminals 30 and 87 i believe then that will mean the relay is telling the pump to be on as soon as your ingnition is turned.
This leads to the fuel pump making funny noises... what sort of noises is it making mate? Sounds like a very simple question but does your car have enough fuel in the tank? If so then it sounds like it could be time for a new pump. If it didnt prime before your bridged the terminal then a new relay could also be on the shopping list
Old Nov 29, 2008 | 11:55 PM
mikey_clough
yeh ive only just filled it with half a tank. other thing i noticed was the relay is not standard, its black, not pink? sometimes it makes quite loud noises even after i turn the ignition off, should it do this? cheers for the help
Old Nov 30, 2008 | 06:33 AM
ROB7656's Avatar
ROB7656
fuel relay is pink mate its under the dash on a bracket in the right footwell above the speaker pod. s1 or s2?
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
15
Oct 7, 2015 03:43 PM
