PC now wont even boot up
Old Nov 28, 2008 | 11:40 AM
glenis's Avatar
glenis
Default PC now wont even boot up
new problem that came out of no where
desktop PC now wont even boot up properly
the machine switches on but does not make any boot up beeps
the monitor just sits there blank with the power indicator flashing
just bought a brand new PSU and this made no difference
have switched the PCI-E graphics card out to another machine and it works fine in that
also put the graphics card into second PCI-E slot and still no difference...
home built pc and has worked fine for 20 months without missing a beat then all of a sudden...
Old Nov 28, 2008 | 12:03 PM
DanRSturbo's Avatar
DanRSturbo
No POST beeps generally means CPU failure. I have experianced it to be the motherbord that's failure, and twice now both componants. I'd start at the cpu first and buy it from somewhere where you can get it refunded / exchanged in case it's the board.
Old Nov 28, 2008 | 12:38 PM
glenis's Avatar
glenis
motherboard is a GIGABYTE GA- M57SLI-S4
one thing that does happen on boot, is the fan on the graphics card goes into high speed mode. must be a fail safe cooling mode if not enough power to it or no boot sequence?!
Old Nov 28, 2008 | 12:47 PM
Sunil_FiestaRS1800's Avatar
Sunil_FiestaRS1800
mainboard,cpu or ram failure
Old Nov 28, 2008 | 12:50 PM
glenis's Avatar
glenis
is that for definate, so i know to buy new...
Old Nov 28, 2008 | 12:56 PM
martysmartie's Avatar
martysmartie
Memory related I would say although normally you would get 3 beeps, try taking each module of memory out (if you have multiple modules) make sure the module and the slot on the motherboard are clean and dust free and re insert.
Old Nov 28, 2008 | 01:03 PM
glenis's Avatar
glenis
ok will try that in a minute
computer makes no beeps at all, at the moment
Old Nov 28, 2008 | 01:13 PM
Sunil_FiestaRS1800
Yea will defo be one if three. As has been said Ram error does usually give a few beeps then no display. But i have known it not to give the beeps before.
Ive also come across the same problem and it was the graphics card. But you have said you had tried yours in another machine so rules that out.
Old Nov 28, 2008 | 01:20 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
sounds like processor failure to me
Old Nov 28, 2008 | 01:36 PM
glenis's Avatar
glenis
tried taking out memory and re-inserting
also removed 12v battery to clear CMOS, both have made no difference
still no beeps at all
very strange indeed as the machine has not burnt out anywhere or made funny noises or any warning signs!
is that possible..?!
Old Nov 28, 2008 | 01:38 PM
Sunil_FiestaRS1800
very strange indeed as the machine has not burnt out anywhere to made funny noises or any warning signs!
yea can happen, seen it a few times. Most of the time turns out to be mainboard. But as i said can be processor or ram too
Old Nov 28, 2008 | 01:39 PM
glenis's Avatar
glenis
cpu chip is a AMD Athlon 64 X2 4600+ AM2 Dual Core 2.4GHz, 512KB x 2 Cache, Retail
Old Nov 28, 2008 | 01:40 PM
glenis's Avatar
glenis
damn, both are Ł50
dont know whether to buy new cpu first or another gigabyte m57sli
Old Nov 28, 2008 | 03:27 PM
martysmartie
In that case I would say the motherboard. If it was the processor you should get something. Do the Power LED and HDD lights work?
I would not buy anything just until you are certain of the faulty component I have had customers do this before only to find something else was at fault.
Old Nov 28, 2008 | 03:53 PM
_SpeedX_'s Avatar
_SpeedX_
i would say processor or mainboard.
unplug everything from the mainboard apart from 1 module of ram and the processor.
so unplug any cd devices, extra ram, e.t.c and try to boot eliminate everything you can before purchasing anything.
norm if theres beeps (depending on how many there are) will norm indicate memory, ide cable wrong way round or somthing along those lines.
Old Nov 28, 2008 | 03:54 PM
_SpeedX_'s Avatar
_SpeedX_
check on ebay for the bits you may find em cheaper seeing as its an older pc
Old Nov 28, 2008 | 03:59 PM
glenis's Avatar
glenis
yes the power LED and HDD lights do illuminate
Old Nov 28, 2008 | 04:00 PM
glenis's Avatar
glenis
but there are no beeps speedX
Old Nov 28, 2008 | 04:14 PM
_SpeedX_'s Avatar
_SpeedX_
which would make me look towards processor or motherboard mate!
Old Nov 28, 2008 | 10:20 PM
Stephen_B's Avatar
Stephen_B
I actually Bum This Place
do you have a mate with the same socket athlon (doesnt have to be same speed - as long as socket is the same your ok) and test that. If it boots its a faulty processor. If it doesnt boot its the mobo!
Old Nov 29, 2008 | 09:56 AM
glenis's Avatar
glenis
just ran the motherboard outside the pc casing with only 1 stick of RAM and the VGA card attached, along with psu obviously
still nothing
so either processor dead or mobo
Old Nov 29, 2008 | 12:24 PM
DanRSturbo's Avatar
DanRSturbo
A guide to POST beeps in case you are curious.
http://www.computerhope.com/beep.htm
Old Nov 29, 2008 | 01:05 PM
glenis's Avatar
glenis
ok thanks, no beeps and no POST screen
its obviously not getting that far, and without a spare mobo or cpu things are going to come to a halt
Old Nov 30, 2008 | 10:47 AM
martysmartie
I would say processor failure more than motherboard failure now.
boeb
Jan 9, 2020 05:11 AM
tankybaby66
Feb 6, 2016 02:24 PM
mk1turboestate
Dec 2, 2015 08:31 PM
chris m1
Sep 7, 2015 08:02 PM
