PC now wont even boot up
new problem that came out of no where
desktop PC now wont even boot up properly
the machine switches on but does not make any boot up beeps
the monitor just sits there blank with the power indicator flashing
just bought a brand new PSU and this made no difference
have switched the PCI-E graphics card out to another machine and it works fine in that
also put the graphics card into second PCI-E slot and still no difference...
home built pc and has worked fine for 20 months without missing a beat then all of a sudden...
No POST beeps generally means CPU failure. I have experianced it to be the motherbord that's failure, and twice now both componants. I'd start at the cpu first and buy it from somewhere where you can get it refunded / exchanged in case it's the board.
motherboard is a GIGABYTE GA- M57SLI-S4
one thing that does happen on boot, is the fan on the graphics card goes into high speed mode. must be a fail safe cooling mode if not enough power to it or no boot sequence?!
Memory related I would say although normally you would get 3 beeps, try taking each module of memory out (if you have multiple modules) make sure the module and the slot on the motherboard are clean and dust free and re insert.
Yea will defo be one if three. As has been said Ram error does usually give a few beeps then no display. But i have known it not to give the beeps before.
Ive also come across the same problem and it was the graphics card. But you have said you had tried yours in another machine so rules that out.
tried taking out memory and re-inserting
also removed 12v battery to clear CMOS, both have made no difference
still no beeps at all
very strange indeed as the machine has not burnt out anywhere or made funny noises or any warning signs!
is that possible..?!
yea can happen, seen it a few times. Most of the time turns out to be mainboard. But as i said can be processor or ram too
In that case I would say the motherboard. If it was the processor you should get something. Do the Power LED and HDD lights work?
I would not buy anything just until you are certain of the faulty component I have had customers do this before only to find something else was at fault.
i would say processor or mainboard.
unplug everything from the mainboard apart from 1 module of ram and the processor.
so unplug any cd devices, extra ram, e.t.c and try to boot eliminate everything you can before purchasing anything.
norm if theres beeps (depending on how many there are) will norm indicate memory, ide cable wrong way round or somthing along those lines.
do you have a mate with the same socket athlon (doesnt have to be same speed - as long as socket is the same your ok) and test that. If it boots its a faulty processor. If it doesnt boot its the mobo!
just ran the motherboard outside the pc casing with only 1 stick of RAM and the VGA card attached, along with psu obviously
still nothing
so either processor dead or mobo
still nothing
chris m1
Sep 7, 2015 08:02 PM
