need a induction kit
Old Nov 26, 2008 | 03:33 PM
Maxxeh's Avatar
Maxxeh
Default need a induction kit
which one shall i get?
Old Nov 26, 2008 | 03:35 PM
andy130's Avatar
andy130
k&n mate is the best
Old Nov 26, 2008 | 07:30 PM
marky_g's Avatar
marky_g
Fleet Manager
think you'll find a drilled air box is the best thing
Old Nov 27, 2008 | 07:10 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
If your running MFI cut the front of your air box and use a k&n flat panel
Old Nov 27, 2008 | 08:55 AM
RSTurboSI's Avatar
RSTurboSI
agreed
Old Nov 27, 2008 | 09:16 AM
marky_g's Avatar
marky_g
Fleet Manager
drilled air box on std filer gives best gains
Old Nov 27, 2008 | 10:24 AM
Turbocabbie
Top Cab !!
im curious as to know what evidence you have to support that this is better than cutting off the front?
If you drill the air box you will get less cold air fed to it than if you cut the front out.
or is it the k&n which you believe is the restriction ?
Old Nov 27, 2008 | 04:13 PM
marky_g's Avatar
marky_g
Fleet Manager
this was tested on my car performance ford a few years ago they have PUBLISHED all the stuff
i believe they tested an
std air box
std air box and panel filter
drilled air box panel filter
drilled air box std filter
induction kit (made less power)
and the drilled air box with std filter came out on top
Nov 1, 2015 06:53 PM
