Shell blasting/dipping?
Old Nov 24, 2008 | 12:17 PM
RickDraper's Avatar
RickDraper
Default Shell blasting/dipping?
I know central blast cleaning do shell dipping but i wondered if there is anyone else people use for this sort of thing?
I need a shell dipping or blasting to get it back to bare metal. I am in cheshire if anyone knows of anywhere localish to me?
Old Nov 24, 2008 | 12:27 PM
costina's Avatar
costina
Live long and prosper!!
i think there called surface processing limited they have advertised in some of the ford mags
they also electro coat too
Paul
Old Nov 24, 2008 | 12:29 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
Just flick through yellow pages, and local sand blaster should be able to do it.
Ive had 4 cars done this way. normally about Ł500 a pop for the blasting.
JUST MAKE SURE THEY USE LOW PRESSURE BLAST
My S1 rst came back with warped pannels cos of an over trigger happy blaster
a few of my
"blasts"
before
blasted and zinced
5 litres of diamond white
1949beetle before
after
To save money id just recomend zinc coating it immediatly after the blast as i did.
A dip is very expensive and i dont think is much more benificial for the cost involved.
Old Nov 24, 2008 | 12:31 PM
Garage19's Avatar
Garage19
There are some issues with dipping that you need to be aware of.
The acid can get trapped in sills etc. and if not properly neuatralised just keeps on eating.
The consensus on turbosport was that media blasting was safer and cheaper.
Old Nov 24, 2008 | 03:08 PM
RickDraper's Avatar
RickDraper
Think my shell might be spending a fair while in the bodwshop anyway as the rear quarter is a bit wobbly!
I have just rang somewhere and they have quoted Ł250 to do inside and underneath. Guess thats quite a good price, and they are mobile. Thing is the dust and grime that will be made when he does it.
Old Nov 24, 2008 | 03:14 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
If you can affort it id get the whole thing done, at least that way you KNOW there is no rust anywhere!
Also unless its a burning hot day in the summer i wouldnt advise a moblie blasting unit.
Ideally you want to have it done in a specail designed workshop, and get that zinc primer on ASAP. MY S1 was in zinc coat 10 mins after being bare metal!!
Old Nov 24, 2008 | 03:18 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Media blasting is the better option IMO.
Rs1's Avatar
Rs1
Ive seen mobile blasting using.......oyster(sp) shells, it just kinda turned to dust and was blown away which didn't matter much as is was enviromentally friendly.
I think you can hire them.
Old Dec 20, 2008 | 01:40 PM
RickDraper's Avatar
RickDraper
Did a bit more digging on this and there is somewhere not a million miles away from me who will blast and prime it for Ł300 which seems a very fair price. They have done a few MK1 escorts in the past as well.
Old Dec 20, 2008 | 03:55 PM
RSandy's Avatar
RSandy
where u located dude?
if its anywhere in the midlands, as for media blasting i can recommend a place in covnetry called marawise, they do plenty of shells iv noticed, and im told work at a competitive rate, they did the blasting on the discovery channel 'beetle crisis' car
if its dipping u want, then theres a place in gornal in the black country (i forget the name sorry ) they are pretty much regarded as 1 of the best, they also did work for the discovery channel 'campervan crisis' show, and have been featured in a few issues of various ford and classic car mags. my old company had a unit in the same industrial estate, and i watched many a project car come in for dipping, from mk1 escorts, to porsches etc
id say media blasting was the much cheaper option, but if controlled correctly, the acid dip will eat rust absolutely everywhere, especially where blastings cnt get to
Old Dec 20, 2008 | 07:21 PM
Iain Mac's Avatar
Iain Mac
The problem I had with blasting was getting the grit out of the sills etc afterwards.
Old Dec 20, 2008 | 07:29 PM
jacko's Avatar
jacko
as said accid needs to be fully sorted after a dip but if you dip it then coat it you get in everywhere the blast cant get to and then covers it as a new car is
Old Dec 20, 2008 | 07:38 PM
GAZ W's Avatar
GAZ W
give these guys a try
www.suttonsodablasting.co.uk
I was there the other day to get some carbs done with excellent results , these guys were also at the classic car show at the NEC with a car on display and the work looked top notch
Here are my carbs
before
AFTER
Old Jan 13, 2011 | 06:52 PM
ScoobySteve's Avatar
ScoobySteve
Hi, I have just purchased a MK1 Escort, its an Aussie import in need of shell cleaning to as high standard as possible. What is my best option please guys, blast or dip???
bobsworth
77
Mar 24, 2016 09:30 PM
gambo08
Feb 4, 2016 10:49 PM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
