EFI fuel pump on MFI system...
Old Feb 16, 2004 | 08:48 AM
Default EFI fuel pump on MFI system...
ive converted my mk5 escy to run a ERST engine using a RS2000 efi fuel pump, will this provided enough fuel pressure to run the system??
if not which in-tank pump can i use
Old Feb 16, 2004 | 08:33 PM
anybody?????????
Old Feb 17, 2004 | 12:09 PM
flashpoint's Avatar
flashpoint
No mate, I don’t think it will as the EFI fuel pressure is a lot lower than the pressure needed to run the mfi system
Steve
Old Feb 17, 2004 | 12:53 PM
oh dear. its in and running at the mo i wont be driving it hard then
what can i use instead??
Old Feb 17, 2004 | 04:04 PM
flashpoint's Avatar
flashpoint
The fact that the car is running must mean that the pump must be capable of supplying sufficient pressure 90 psi but can is supply sufficient fuel under load, on boost to maintain that pressure
Fit a fuel pressure gauge and find out
Steve
Old Feb 17, 2004 | 05:33 PM
it seems to go ok under boost
fit a fuel pressure gauge you say, u mean buy a guage and install it inside and cry when its not enough
cheers for the help
Old Feb 19, 2004 | 11:17 AM
tonypastie's Avatar
tonypastie
will be ok until it is,nt ie you will not no until its to late
also never bring fuel into the car most dangerous! use a electrionic type of gauge you can read in the car!
Old Feb 20, 2004 | 09:22 PM
i hope im not stupid enopugh to run fuel to a gauge inside the car
doesnt sound good on the fuel pump front thou
Old Feb 24, 2004 | 04:54 PM
and the answer is NO the EFi pump is nowhere near good enough either in pressure or fuel flow
ive had to order a "motorsport" one. i suppose that tag justifies its 135+vat price tag oh well it will sort my car out anyways
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
dms04
Sep 11, 2015 01:57 PM
stevierob
Sep 7, 2015 07:09 PM
