Problem starting my focus ST
Old Nov 23, 2008 | 08:37 PM
focus st2's Avatar
focus st2
Default Problem starting my focus ST
Question for any technical lads on here. Yesterday morning i had a problem trying to start my ST.
Turned the key in the ignition and all i got was beeps and warning lights The engine wouldn't turn over at all
The warnings that came up on the dash were reduced acceleration and engine systems failure
Since i was already late for work i left the car in the driveway and took the misses car.
When i got back from work in the afternoon i tried to start the car again and all was ok. First click of the key and it started without any problem (no warnings at all)
First thing this morning i went out to see if it had the same problems as yesterday but it started on the first turn of the key again
I'm gonna book the car into the dealership in the morning for a check up to see if there is any problem
I'm just wondering has anyone ever came across this or even heard of it before?
Cheers for any help
Old Oct 21, 2011 | 10:08 PM
gunner06's Avatar
gunner06
my 06 st3 did the exact same today?
Did you ever find out what caused it?
Old Oct 21, 2011 | 10:10 PM
pani_k's Avatar
pani_k
PassionFORD Member
Lovely that 568 views and nobody has any advice for the guy
My first port of call would be to check the battery mate and check for any loose connections.
Old Oct 21, 2011 | 10:13 PM
gunner06's Avatar
gunner06
the battery was fine cause the radio and lights worked.
But i disconnected it for a sec, put connectors back on and away she went. Does disconnecting the battery reset the ECU on the focus?
Old Oct 21, 2011 | 10:19 PM
pani_k's Avatar
pani_k
PassionFORD Member
Just because the radio and lights work doesn't mean the battery is any good mate especially when it comes to the business of cranking if it doesn't hold good charge and have enough voltage the plates will simply collapse and nothing will happen. I don't know whether ST's have the same function but leaving the battery disconnected for around 30 minutes does reset the ECU keep alive memory for the older MK1 focus' not sure on the MK2s. Can give it a try however.
Old Oct 22, 2011 | 05:04 PM
AndyNo1's Avatar
AndyNo1
I'd go along with what Pani has said.
Old Oct 22, 2011 | 05:40 PM
alexno1dj's Avatar
alexno1dj
check earth connections, i had this problem on a car of mine after a new clutch and turned out the earth strap bolt onto the block was loose
Old Oct 22, 2011 | 05:48 PM
duncans90's Avatar
duncans90
Removing Fuse 26 for around 20-30 mins will reset your ecu and clear any current faults
Old Oct 22, 2011 | 05:57 PM
Dave Parker's Avatar
Dave Parker
he must have it sorted now its three years ago
Old Oct 22, 2011 | 06:47 PM
duncans90's Avatar
duncans90
I believe we are now offering advice to gunner06 as he said he had the same problem
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
taylora1409
Aug 12, 2015 12:06 PM
