Rear arm bushes
Old Nov 23, 2008 | 02:20 PM
Karl 3dr's Avatar
Karl 3dr
Default Rear arm bushes
I've recently bought a set of polybushes for my Sapph and the plan was to replace the swinging arm bushes with the proper Ford bushes because of the bearings in them, i've checked with Ford though and you cant get the full set of them anymore, does anyone know of anywhere that still does them?
Thanks, Karl
Old Nov 23, 2008 | 02:22 PM
KSA-Cossie's Avatar
KSA-Cossie
Afraid not karl,i have a brand new set of the big ones but waiting on the small ones from ford.
Old Nov 23, 2008 | 04:15 PM
155lee's Avatar
155lee
i had them in mine,when i changed them to poly bushes they were a total mare to remove.
Old Nov 23, 2008 | 04:20 PM
Sonic Boom's Avatar
Sonic Boom
Same here I had the press upto 13 Tonnne to get the one out, it went will a hell of a bang!!
Rich
Old Nov 23, 2008 | 05:28 PM
STUCOS's Avatar
STUCOS
know lambchop has a pr of the large size he might sell,and mike r might be getting them reproduced,duncan at auto unlimited did have sets at Ł150 per arm plus postage
cheeRS stu
Old Nov 23, 2008 | 05:49 PM
cossie604's Avatar
cossie604
Rich
Dont they just...proper bang
Old Nov 23, 2008 | 06:53 PM
charlie luciano's Avatar
charlie luciano
Automotive unlimited have one side for sale, Ł149, have a butch on ebay
Luciano
Old Nov 24, 2008 | 09:32 AM
For that price you might as well buy two h/d rod end bearings, and mod the arm for adjustable camber and toe, and still have money over.
Old Nov 24, 2008 | 12:46 PM
Karl 3dr's Avatar
Karl 3dr
Thanks for the replies, has anyone polybushed the rear arms?
What does it drive like?
I know its the wrong thing to do but if i cant get the proper bushes this mighht be my only option.
Cheers, Karl
Old Nov 24, 2008 | 12:47 PM
Karl 3dr's Avatar
Karl 3dr
Have you got any more info on doing this or pics of it done?
Cheers, Karl
Old Nov 24, 2008 | 06:36 PM
155lee's Avatar
155lee
why is it a bad idea to polybush the rear arms?i done mine,was it a bad idea?
Old Nov 24, 2008 | 06:48 PM
Karl 3dr's Avatar
Karl 3dr
The original bushes have a bearing in them whereas the polybushes are just a solid bush so effectively you're downgrading when fitting the polybush.
I've been told by a few people not to do it but there may be no other option.
How does yours drive now by the way?
Old Nov 24, 2008 | 07:31 PM
155lee's Avatar
155lee
the bushes were shagged before so it drives loads better.mine is a bit twitchy at the front,but my steering coupling is split and perished and i have 3mm spacers on the front wheels so im putting it down to that.apart from that its great.at Ł150 per side i think i would get an adjustable rear beam.
Old Nov 24, 2008 | 07:35 PM
Karl 3dr's Avatar
Karl 3dr
Yeah, thats the other option, lol.
Ł300 for 4 bushes is a lot of money!!
Old Nov 24, 2008 | 08:31 PM
155lee's Avatar
155lee
plus the hassle of taking the arms off to have them removed/fitted.mine needed new brake pipes at the same time,and the abs clips broke.is that compomotive mo,s you have on your car?i fancy a set for my car.i have rs diamond cuts on mine,if i get them sold ill buy the compos.
Old Nov 25, 2008 | 12:17 PM
Karl 3dr's Avatar
Karl 3dr
Yeah, they are mate, mine are 7.5x17 ET37
rex647
Mar 6, 2022 06:20 AM
155lee
Oct 27, 2015 04:55 AM
Tony W
Sep 9, 2015 12:08 PM
rsturbo27
Sep 5, 2015 05:08 PM
