A different question
Old Nov 16, 2008 | 02:14 PM
Butchi's Avatar
Butchi
Default A different question
Im wondering if any of you guys can tell me how the engine oil getting from the oil pump to the head and in to these small holes were the lifters are?
BR Butchi
Old Nov 16, 2008 | 02:25 PM
B16CVH's Avatar
B16CVH
BR Butchi
The oil passes through the oil gallery into the filter, it then leaves the filter into the second gallery which feeds the mains then the big ends. This seconday gallery has a vertical feed which rises up at the rear of the block where it meets the oil gallery i the head.
This gallery feeds the main bearings of the cam and ultimatley the lifters in the head. The feed for theses can be found in the lifter bores and run directly from the bearing feeds!
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
