S2 brake problems
Old Nov 16, 2008 | 11:41 AM
S2 Craig's Avatar
S2 Craig
Angry S2 brake problems
Hi,
Just replaced rear brake pips on my escort and replaced the master cylinder with a patent lucas cylinder, cant seem to get a good pedal. Keep bleeding it, pedal pumps up but when leaving and re-applying it goes straight to the floor. I have tried 2 master cylinders, these master cyliders have 4 ports. I have blocked off 2 of them cos I am still running with the standard abs. Am thinking maybe I should try and genuine master cylinder, itdoesnt seem to be pushing that much pressure.
PLEASE HELP!
Old Nov 16, 2008 | 12:00 PM
Chris69's Avatar
Chris69
the car needs to be flat to bleed the rear or at least the hubs/wheels need to be.( because of the rear compensators in case you didn't know)
does sound like air still in the system to me and with two blocked the master cylinder should work fine imo.
Old Nov 16, 2008 | 12:45 PM
Rick's Avatar
Rick
are u getting fluid out of the rears?
Old Nov 16, 2008 | 04:44 PM
S2 Craig's Avatar
S2 Craig
ye, ive got the rear wheels on the ground, and i can see the valves operating. i am getting fluid out the back, but i would like to see more presure.
if u think the cylinders rite, do u think it could be somthin to do with the ABS.
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
