Dump valve
Old Nov 13, 2008 | 05:34 PM
R5AAL's Avatar
R5AAL
Default Dump valve
I am thinking about fitting a dump valve to my FRS,i know it has to be a twin piston due to the air mass meter but was wondering what ones everyone else has?
I'm thinking about a baily DV36, the venturi style one does anyone know if it sounds good?
Old Nov 14, 2008 | 01:20 PM
cootsie's Avatar
cootsie
I wouldn't use a atmos DV Like the DV36.You may end up with stalling problems.
The FRS likes a recirculating DV like the Forge 007. If you are looking for the 'dump' noise change the air filter to a GEN II and you will hear the dump valve.
Old Nov 14, 2008 | 04:11 PM
RS16iDale's Avatar
RS16iDale
i want mine to chatter rather than dump idealy, i was thinkin of gettin k&n gen 2 and if need to the forge recirculating valve.
do you know wot sort of noise this would give?
Old Nov 14, 2008 | 05:43 PM
bick888's Avatar
bick888
It would probably sound a bit like a fart!
lol, would sound bad mate!!
Old Nov 16, 2008 | 02:15 PM
Alex the kid's Avatar
Alex the kid
ive got a ggr dv on mine never had any problems
Old Nov 23, 2008 | 10:42 AM
jonnyfocus's Avatar
jonnyfocus
Stick a forge 007 as cootie mentioned and a K&N gen 2 and it will sound the same as an atmospheric DV.
Old Nov 30, 2008 | 06:54 PM
RS16iDale's Avatar
RS16iDale
so how do u get it to chatter rather than dump?
Old Dec 1, 2008 | 01:41 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
remove the d/valve all together and bung it up. Apparentl;y not the done thing on FRS though as it could kill the turbo. On a cossie its great though
Old Dec 2, 2008 | 07:29 PM
FMC 9V's Avatar
FMC 9V
I had a GGR atmospheric dump valve on my Focus Rs, to stop it stalling i had to adjust the base idle speed.
Old Dec 3, 2008 | 08:25 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
why the different name here? just registered?
surely thats not a great thing to do? Couldnt you do the ecu reset with disconnecting the battery for 10 mins? My car stalled at start but "learned" and after 100 miles ish was fine!
Old Dec 3, 2008 | 04:14 PM
FMC 9V's Avatar
FMC 9V
Been registered for a while but always on the rs bb!! That's the reg i was after at the time i joined this forum, so that's why.
Don't need to worry about dump valves now,don't think i'll be fitting one...
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
