no ignition lights
started my car up today and let it run for a short while...i then turned it off but when i tried to start again straight after i got no ignition lights....can any1 point me in the right direction? properly baffled by this one...cheers
oops lol....no i wudnt start again..starter motor didnt click or owt...it dont have an immobilisor(sp) or alarm....there seemed to be plenty of life in the baterry when it first started but will double check 2morrow. are there any fuses/relays that may have blown?
does sound like the battery, only other thing springs to mind is the small wires that goes to the positive (+) battery terminal,if that has broken off you wont get no ignition so check its in good condition.
i hope its just the battery as i can take it back under warranty. its only 2 days old...never crossed my mind bout a broken wire as all i did was turn it off then tried to restart it, i never touched a thing that would cause a wire to break..cheers for the replies lads
Dr. Ickxs
Sep 15, 2015 10:15 PM
The Enigma
Sep 12, 2015 10:12 PM
