Copper Turbo Down Pipe Gasket
Old Nov 10, 2008 | 06:58 PM
Sonic Boom's Avatar
Sonic Boom
Default Copper Turbo Down Pipe Gasket
I remember a long while ago some used to make a copper gasket that went between the down pipe and the turbo.
Does anyone know if these are still made? and if so by whom?
Cheers Rich
Old Nov 11, 2008 | 09:53 PM
Sonic Boom's Avatar
Sonic Boom
Anyone?
Old Nov 12, 2008 | 07:06 AM
I never knew anyone made these, but easy enough to make yourself if you want some, and for only a coulpe of £'s, just need a piece of wood and some drill bits.
Old Nov 12, 2008 | 03:27 PM
Sonic Boom's Avatar
Sonic Boom
How would I make it?
It would be like a 3" ring with a tapered edge, so it would fit snug againest the turbo exhaust housing then the down pipe flange would butt up to it.
Rich
Old Nov 12, 2008 | 04:31 PM
Ridgey's Avatar
Ridgey
Big drill bit
Old Nov 13, 2008 | 07:36 AM
Bollocks for some odd reason I read DRAIN and not DOWN, and thought you meant the drain tube , sorry.
I'm not aware of anyone making any for this area, but FERRIDAY ENGINEERING would know if anyone does.
Old Nov 13, 2008 | 06:07 PM
TurboShed's Avatar
TurboShed
Cossiemodo
What would you want to fit one??
Old Nov 13, 2008 | 08:40 PM
Sonic Boom's Avatar
Sonic Boom
Just to stop a small leak I have, i've changed the bolts and cleaned up the flanges but I still get small leak under boost I can see soot on the under side of bonnet.
Rich
Old Nov 14, 2008 | 07:00 AM
Have a careful look at your downpipe flange to see if it has a little ridge where the flare is, as this can cause this, just a little time with a file soon sorts it, best to take pipe off though, failing that put some firegum on it.
Old Nov 14, 2008 | 08:02 PM
Sonic Boom's Avatar
Sonic Boom
I'll have a good look at the flange tomorrow morning.
Rich
Old Nov 16, 2008 | 08:43 PM
dox's Avatar
dox
jus smooth off the high spots with a file......never seen a gasket for the turbo/downpipe flages lol. i also dont think copper would be the best bet either
as it work hardens an caracks then falls to bits inless your gonna pull it
out and anneal it every so often.
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
mint_s2
Sep 2, 2015 08:58 AM
AndrewStrang
Sep 1, 2015 11:16 AM
mrknifey
Aug 30, 2015 11:48 AM
