Wasted spark?
Old Nov 9, 2008 | 04:19 PM
Lars_Ferm's Avatar
Lars_Ferm
Default Wasted spark?
Can someone explain how its done,what u need etc-a guide
Old Nov 9, 2008 | 04:32 PM
Stu @ M Developments's Avatar
PassionFords Creator
This may help?
http://www.motorsport-developments.c...stedspark.html
Old Nov 9, 2008 | 04:47 PM
Lars_Ferm's Avatar
Lars_Ferm
Ok so i send my P8 ecu and u make it happen.does it mess mess anything else whit the ecu? i can get it remapped whit no problem?Do u use some special leads or can i use 8,5mm magnacor?
Old Nov 9, 2008 | 08:06 PM
ECU remains as it was. Its available DIY for P8 too if your interested, but bear in mind that if your in the market for a new ecu calibration (Chip) then it can be done in the chip too with no need for a driver at all.
Old Nov 9, 2008 | 08:37 PM
Lars_Ferm's Avatar
Lars_Ferm
Whats diy? but if i send my box to u and u set up for wasted spark will work whit the chip i got in now? the car is calibraited whit my current set up no 330chip or so.
Old Nov 9, 2008 | 08:42 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
diy = do it yourself
Old Nov 10, 2008 | 09:49 PM
Dave Henshall's Avatar
Dave Henshall
lars,
there are 4 options:
you can either fit the DIY kit to your own ecu that will use your existing chip.
you can send your ecu to msd and they fit the kit and use your existing chip.
you can fit the msd wasted spark chip to your own ecu.
you can send your ecu to msd and they fit the new wasyted spark chip.
the 1st 2 options allow you use the existing rev counter as kit includes a rev counter driver. with the water spark chip only - you will need to fit a rs2K rev counter or aftermarket one so that your rev counter works.
Old Dec 1, 2008 | 03:19 PM
Lars_Ferm's Avatar
Lars_Ferm
where can i get the kits?what do they include.
Old Dec 1, 2008 | 03:23 PM
http://cgi.ebay.co.uk/ws/eBayISAPI.d...e=STRK:MESE:IT
Money to be saved on the kits here:
https://passionford.com/forum/general-car-related-discussion/269907-credit-crunch-beating-xmas-discounts-prices-now-available-on-page-3-a.html
Old Dec 1, 2008 | 05:08 PM
KSA-Cossie's Avatar
KSA-Cossie
One of the best things you can fit to a cossie.
DixieTheKid
11
Jun 6, 2020 11:20 AM
deathrider666
Sep 28, 2015 06:12 PM
pabloXR
Sep 21, 2015 12:42 PM
beller
Sep 21, 2015 04:13 AM
DixieTheKid
Sep 14, 2015 09:04 PM
