seized calliper
just notice my handbrake is seized on 1 side so i tried freeing it with wd40 got it to free but now when you put handbrake on and take it off it doesnt release all the way as if the spring isnt strong enough is it poss to take the handbrake mechanism apart and clean and re grease if so how is it done tried to remove already but will only come up so far and not out all the way cheers in advance for help
remove caliper
remove piston
remove a couple of circlips (after making a special tool from the remains of an old piston)
remove handbrake operating arm
clean out and re-grease
replace shagged operating arm seal
re-assemble
or just go to Looms and pay a fiver for a good one
remove piston
re-assemble
track.focus'd
Aug 12, 2015 05:53 PM
