Top speed
Old Nov 2, 2008 | 04:15 PM
robA's Avatar
robA
Default Top speed
What should be the top speed of a 4x4 cossie
I tried today , 6000 rpm at 133 mp/h , does that soud correct?
Old Nov 2, 2008 | 05:26 PM
Fast Ford quote 150mph, but I think that is just the manufacturers figures, I think nearer 140-145 is more the norm, not seen a road test as such.
best idea to look on web for road tests etc.
Old Nov 2, 2008 | 05:55 PM
robA's Avatar
robA
Post
you all drive cossie's , so what do others have , speed and rpm ?
Old Nov 2, 2008 | 05:57 PM
mechanic28's Avatar
mechanic28
6rpm in 5th and your speedo was showing 133mph??
Old Nov 2, 2008 | 06:04 PM
robA's Avatar
robA
Post
yes 6000 rpm and 220k/h (220 is 133 miles hour)
i'm running 17 inch rims with 215/40/17 tyres
Old Nov 2, 2008 | 06:07 PM
graham c's Avatar
graham c
150 plus i would think
Old Nov 2, 2008 | 06:08 PM
mechanic28's Avatar
mechanic28
that aint right on my 2wd i have had my speedo over 160mph on a few ocassions!!you sure you got standard ratios etc?
Old Nov 2, 2008 | 06:13 PM
dojj's Avatar
dojj
Resident Wrestling Legend
it should be 141mph
dojj's Avatar
dojj
http://www.gearboxman.co.uk/inforatios.html#download
Old Nov 2, 2008 | 06:17 PM
robA's Avatar
robA
i guess i best try a navi in the car and read the gps speed , prob the most accuarte way of knowing what speed i'm doing !
Old Nov 2, 2008 | 06:19 PM
Tev's Avatar
Tev
ive had mine round bout the 160 mph mark a couple of times(private test track ofcourse)
but all speedos read wrong, bout 10% out and i would assume that due to age of car it would b worse on a cossie,
be careful though holding the car on full throttle for long stints in 5th it can all go wrong quickly
Old Nov 2, 2008 | 06:23 PM
robA's Avatar
robA
i guess the speedo is miles out , rolling radius for std tyres size is different from the 17 inch
rev counter should be fine , it's on multi coils from stu !
i go to germany to do this , first proper motor way is 10 miles away from my house
Old Nov 2, 2008 | 06:34 PM
Tev's Avatar
Tev
dont quote me on this but i think at 2000rpm in first you will b doing 10mph
2nd-20mph
3rd-30mph
4th-40mph
5th-50mph
mechanic28's Avatar
mechanic28
yes thats true even the the speedo is showing 160 plus probably ony doing a true 140 odd!but a cossie can do over 150 in standard format!
Old Nov 2, 2008 | 06:40 PM
robA's Avatar
robA
6000 rpm will be 150 miles/hour or 247, km/h
Old Nov 2, 2008 | 08:36 PM
graham c's Avatar
graham c
a 2wd saff will go off the clock on a stage three so thats well over 141 even if the speedo,s out
Old Nov 3, 2008 | 06:25 AM
robA's Avatar
robA
Post
Gearbox: Five-speed Ford MT75.
Internal ratios: 1st, 3.62; 2nd, 2.08; 3rd, 1.36; 4th, 1:1; 5th, 0.83.
Final drive: 3.62:1, 22.24 mph per 1,000 rpm in 5th.
this is what i found at a geocities site
http://www.geocities.com/cossie21/
Old Nov 3, 2008 | 06:29 AM
robA's Avatar
robA
Post
(optional)
shift point: 6000 RPM
rev drop speed MPH
1st to 2nd 2552 31
2nd to 3rd 2077 55
3rd to 4th 1588 84
4th to 5th 1020 114
5th top speed 137
engine speed 6000 rpm /roadspeed 137 mph / tyres size 205-50-15
Old Nov 3, 2008 | 06:30 AM
robA's Avatar
robA
Post
(optional)
rev drop speed MPH
1st to 2nd 2552 32
2nd to 3rd 2077 56
3rd to 4th 1588 86
4th to 5th 1020 117
5th top speed 141
max engine speed 6000 rpm/roadspeed 141 mph / tyre size 215-40-17
Old Nov 3, 2008 | 07:07 AM
dojj's Avatar
dojj
they won't believe you beause your figures are based on maths and not arse dyno's as seen on youtube speedo videos
Old Nov 3, 2008 | 08:01 AM
bigjim172000's Avatar
bigjim172000
Me Cossie Runs Atlast!!!!
Funny but so true
Old Nov 3, 2008 | 08:05 AM
robA's Avatar
robA
Post
It's just some figures , that's all i just wanted to know what the real speed is (or should be at 6000 rpm )
Regards Rob
jessie_rs
62
Aug 6, 2019 09:27 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
rsturbo27
Sep 5, 2015 05:08 PM
hopper350
Sep 4, 2015 12:53 AM
