cold start?
Old Nov 1, 2008 | 11:03 PM
biggiejody's Avatar
biggiejody
Default cold start?
has a cossie got a cold start or something simular? as when i first start mine it idles arout 1100 but as soon as i go to move it and dip clutch it shoots up to about 2k and dropd slowly back to around 1100. then it warms up and its fine.
also got a slight misfire when warm at 1900 k and clears it self as soon as over 2k. or under 1900
would any of it be an idle control valve? if so where abouts in the bay is it?
2wd 90 cossie by the way, cheers
Old Nov 2, 2008 | 06:32 AM
The idle control valve is on top of the throttle housing a cylindrical unit with the end inside the housing itself, held oin by a ring around it's base with two screws, and has a electrical TWO pin plug going to it as well, the top half is grey plastic the lower half is stainless steel.
The fact that it is able to raise the revs shows it to be working, I would check your tps output, then if you have not done so in the last few years I would replace the cts.
Old Nov 7, 2008 | 09:58 PM
biggiejody's Avatar
biggiejody
as im quite new to cossies is it possible u can tell me where the sensors are?
i no where the crank sensor is and the phase sensor lol
and whats a tps output?
thanks
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
gingeRS
Sep 4, 2015 06:29 PM
