Oil pump
Hello.
I have a queastion about the oil pump in ours car.
In Haneys book they write that if you want to remove the oil pump, you must lowering the engine or take the engine out.
Is this the only way to change to a new pump?
One more question pleae. Should a go for a HP pump on ebay or should a buy a standard from Ford? Is there any side effects on the HP pump?
Br Butchi
Br Butchi
Hello.
Br Butchi
Br Butchi
you can get the pump off by removing the engine mount on the inner wing and lowering it, buy a high pressure oil pump from someone like matt lewis.
+447910818110.
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
