Saff Cossie 4x4 idling
Old Oct 30, 2008 | 06:28 PM
Default Saff Cossie 4x4 idling
Ive got a saff cossie 4x4 and the engine has been idling crap for a few months now.It normaly idles at over 1000 rpm.When i disconnect the idle speed contorl valve it idles at about 7.50/8.50rpm.I know the revs will drop when the iscv is unplugged.Does the base idle need setting up.Sometimes when i im warming my car up on a morning before i go to work the revs go up and down a few times every now and then.Do i have a faulty iscv.Ive cleaned the valve out many a time too and lubed.Any help would be great people.
Old Oct 30, 2008 | 06:32 PM
Captain500rs's Avatar
Captain500rs
Mine does it glenn only does it for a few seconds wen a first start it up,just thought it was normal,think thing wi sitting over 100rpm,mine sits exactly on 1000rpm thought it had to de this to keep the oil pressure up
Old Oct 30, 2008 | 07:38 PM
T4matt's Avatar
T4matt
Big or small fxck em all
Think you just need your base idle setting up mine was the same,
Old Oct 31, 2008 | 05:22 PM
Get the car warm and set your base idle to about 950 rpm.
The fact that the revs go up and down shows the valve to be working as it is this that is causing the differing idle, this can however be made a lot worse by lean mixtures, so a co check would be a good idea.
Old Oct 31, 2008 | 05:26 PM
kosman's Avatar
kosman
sideways all the way!
my 2wd does the revs up and down two or three times b4 settling bang on 1000rpm,my bro's had your problem and he had to have the vavle changed and a full setup and co check
Old Oct 31, 2008 | 06:04 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
check tps signal and settings,
check ect sensor and resistance against temp
check ecu voltage,
check base idle when hot,
check fuel pressure/co and adjust according to your tuners instructions,
pressure test inlet, and rectify any air leaks.
failing that, speak to your tuner about a different idle strategy
Old Nov 1, 2008 | 11:09 PM
I know my fuel mixture is a bit rich.Whats the best way to set the base idle then.
Old Nov 1, 2008 | 11:11 PM
jacko's Avatar
jacko
best way is to pop in mate ill do it for you for free
Old Nov 1, 2008 | 11:14 PM
I have seen the screw under the throttle body.If i find time i would pop through.Is your garage easy to find then.
Old Nov 1, 2008 | 11:16 PM
jacko's Avatar
jacko
easy enough snowdon rd middlesbrough
Old Nov 1, 2008 | 11:17 PM
jacko's Avatar
jacko
have to do it warm and ill check all the senssors and gaps and clean the idle valve
Old Nov 1, 2008 | 11:36 PM
It might have to be on a weekend or less your still at your work after 5 at night.
Old Nov 1, 2008 | 11:42 PM
mechanic28's Avatar
mechanic28
after you have set your base idle if your idle goes up and down after you plug your iscv back in,you need to set your tps up!
jacko's Avatar
jacko
im there tomorow mate
Old Nov 2, 2008 | 12:10 AM
BigErn's Avatar
BigErn
Your always bloody there, hope its not too long before you can get normal finishes mate or you'll burn yourself out. Plus you need to find time to start training again.
Old Nov 2, 2008 | 12:32 AM
Im busy tomorrow ive got a bloody christening to go to.
TPM961
Jan 15, 2018 10:50 AM
RSmark84
Sep 13, 2015 01:29 PM
truffleshuffle
Sep 10, 2015 09:35 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
