Chris Fisher
Could the Real Chris Fisher please stand up lol
As my Thread for the Wing and rear insert vinyl's was deleted, i lost the list.
Just to let you know, i recieved your cheque and should have the set out to you very soon, my cousins is hoping to get them cut by end of this week.....
DOH, yep Gareth Fisher... lol Sorry dude, i done this post at work and had your letter at home.
But i got your cheque ok and should have your set with you soon, but ill keep in touch.
rear bumper inserts - the black vinly section that runs across the little inset towards the bottom of the rear bumper.
Wing stickers - if you open the doors and look at the back of the wings, there are some balck vinyl sections shaped around the fixings.
the awkward thing with these is that they are made of a weird textured vinyl that has proven very hard to source for replacements - Martin (RedRSmk5) was doing them for a while thru his contact until his contact started getting greedy with the prices - but now Glen has sourced someone to continue helping the guys out from where Martin left off.
Hope that helps
Hope that helps
if you have seen a factory ready rear escort cossie bumper, it has a textured black finish to the insert bit and also the same type textured vinyl piece on the inside of the wings where you can see when you open the doors.
basically martin had these replicated, but his supplier got greedy, so i offered to take over the duty of supplying these.
thought it was these i was going to get some made for a costomers car and get some extra done to as ford have no clue about them
but if there cheep enough it would be easier to buy what i need
DixieTheKid
11
Jun 6, 2020 11:20 AM
DixieTheKid
Sep 14, 2015 09:04 PM
And i think i forgot to put my username in with the cheque i sent you
