st200 water pump????
Old Oct 26, 2008 | 07:53 PM
ghigo's Avatar
ghigo
Default st200 water pump????
hey people, i just picked up an st200 yesterday and am over the moon with it. ive heard they suffer waterpump issues with the early plastic impeller ones and am not sure if its got the uprated metal item, is there an easy way to check without removing it like a different part number or visual different in the casing or something. any help appreiated cheers
Old Oct 28, 2008 | 07:36 PM
ECOS95's Avatar
ECOS95
The metal pump that I fitted had a gold pulley while the original one was black.
Old Oct 28, 2008 | 07:48 PM
ghigo's Avatar
ghigo
cheers mate,
i shall have a look,
what they like to change cos there aint alot room under that bonnet lol
is there anything else to look out for on these, common faults ect
Old Oct 28, 2008 | 07:53 PM
The Youth.'s Avatar
The Youth.
dead easy to change, they are under the black plastic IMRC cover(has 2.5v6 bla bla written on it), near the battery, remove the cover and then the belt, undo the 8 or so bolts some will be long remember where they came from!
remove the pump, the scrape off the old gasket, then to refit reverse the above!
steve
Old Oct 28, 2008 | 10:12 PM
Easy to do mate i did my friends on my front.The hardest part about doing it was getting the old paper gasket off.
Old Oct 29, 2008 | 05:11 PM
ghigo's Avatar
ghigo
cheers guys thanks for your help,
doesnt look like its had the uprated item so shall buy and fit one soon!!!!
Old Oct 30, 2008 | 12:14 AM
minty1964's Avatar
minty1964
here one http://cgi.ebay.co.uk/FORD-MONDEO-2-...d=p3286.c0.m14
Old Oct 30, 2008 | 12:29 AM
Fiddy's Avatar
Fiddy
Im the freind lol. as glenn said, the hardest part was getting the old gasket off. this is the pump i used, got it from partco, was about £40.
Old Oct 31, 2008 | 02:58 PM
ghigo's Avatar
ghigo
kool cheers again guys,
have ordered one of ebay so will fit when arrives
Old Nov 7, 2008 | 01:27 PM
Farmer Giles's Avatar
Farmer Giles
lifting the battery out will give you a little extra room to work, but you can do it without removing the battery if you don't have your radio code etc...
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
