Sapphire front wing replacement - Ford / Pattern ??
I need 2 new front wings on my Sapphire. Do Ford still do them? Or do pattern ones exist, if so what's the fit/quality like?
Thanks in advance
Thanks in advance
Odd people say this about pattern parts, when a lot of the time they are done on the same presses that have been sold on.
It is not financially viable for someone to make the die etc for stamping out pattern wings for a ever decreasing market so they buy the oe old ones, true they are a bit worn from all the pressings.
I bought two new Hadrian wings for mine and the fit was 100% perfect, no better no worse than new genuine ones, the guy who did the work, works for Norwich Union as a repair estimator and it was his recommendation of make.
I also used thier front slam panel, bonnet, cross member, etc etc, all was ok, apart from the bonnet the interior frame bit was not bonded to the skin!
Pretty sure there is one on ebay at the moment
Here is the link
http://cgi.ebay.co.uk/Ford-sierra-mk...d=p3286.c0.m14
Luciano
if you get a ford one it has the ford stamp but if your like me you can cut the date stamp out of the old wing put it in the new one then fit it and if your good with sealler no one knows its ever been changed
have a butchers
Here is the link
Luciano
Here is the link
Luciano
cheeRS daz
to post up an ebay link, when looking at an item on the listing page, right click it and choose the copy shortcut option, then right click again when in the post reply box and select paste
job doneLuciano
have a butchers
Here is the link
Luciano
Here is the link
Luciano
daz
You Would have to be really really! GOOD at sealing to not be noticed that the wing has been changed!
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
paceo
12
Aug 4, 2015 08:50 PM
