What wire????
Old Oct 24, 2008 | 05:10 AM
BRAMMER's Avatar
BRAMMER
Default What wire????
Due to not having a Haynes manual i don't know which wire to go off for the illumination from the clocks.
Any help
Cheers.
Chris
Old Oct 24, 2008 | 10:20 AM
stevecossy's Avatar
stevecossy
Where are you fitting the gauge bud? I took my feed from the clock loom as removed clock and put gauges in there.
Cheers steve
Old Oct 24, 2008 | 01:22 PM
BRAMMER's Avatar
BRAMMER
I have an A pillar pod but want the light on the gauge to operate the same as the dash lights
Old Oct 24, 2008 | 03:26 PM
AndyPen's Avatar
AndyPen
Cant you take it from the dimmer switch then, could be the easiest bet??
Old Oct 24, 2008 | 04:07 PM
iansoutham's Avatar
iansoutham
OCD Victim
You want the grey/yellow trace wire that goes to the back of the dash clocks. connect your +12V illumination wire into that and it will dim the same as the main clocks.
However, make sure to check that you do not have an LED instead as if you dim the lights, it will simply turn off instead of dimming.
Old Oct 24, 2008 | 04:37 PM
BRAMMER's Avatar
BRAMMER
Cheers Ian thats what i needed to know mate.
Old Oct 30, 2008 | 02:36 PM
BRAMMER's Avatar
BRAMMER
Slight problem mate i don't have a grey/yellow wire.
If anyone can give me the number of the slot on the plug i will go off that.
Or if anyone can confirm the colour of the wire on a 86 3dr
The dim switch has 2x grey/green 1x grey & 1x brown which one could i go off
Cheers.
Old Oct 30, 2008 | 05:53 PM
capri280's Avatar
capri280
Default help
took mine from the feed going to the bulb in the ashtray
Old Oct 30, 2008 | 08:59 PM
iansoutham's Avatar
iansoutham
OCD Victim
Cheers.
One of the grey/green wires will be fine.
Old Oct 30, 2008 | 09:06 PM
bigjim172000's Avatar
bigjim172000
Me Cossie Runs Atlast!!!!
Just get the clocks out, look at the bulb holders for the sidelights on it, track back the wire to the connector and use a volt meter to work out which one is the feed and earth, job jone.
Old Oct 30, 2008 | 09:41 PM
Jimboxr4x4's Avatar
Jimboxr4x4
There are 4 wires on the connector to back of clock if I recall correctly. One is +12ve to power the clock, one is +12ve only when lights are on and the other two are earths. Just put a voltmeter across them all and the one that shows 12 volts only when lights on is the one you want. Good luck.
Old Oct 31, 2008 | 05:53 AM
stevecossy's Avatar
stevecossy
Thats what i did and was trying to say.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
