Rs Turbo non starter (fuel pump)?!
left my rs parked up for 2 weeks, started perfect short drive later, parked it up for 5 mins, went back an it wont start, the prime/buzz sound on the fuel pump sounds weak an like its blowing air, thers petrol in it, fuel pump shagged?
i had the same prob how much fuels going to the fuel filter is it spraying out. get a volt meter and see how much volts you got should be 12 volt. whats your meter unit like could be worn
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
