efi water pipes???
Old Oct 23, 2008 | 02:53 PM
paul66 turbo's Avatar
paul66 turbo
Default efi water pipes???
its a s2 with efi engine, ive got my engine back in the car and nt sure where some pipes go,on the mfi setup the two pipes that come out of the oil cooler go into the two outlets on the inlet manifold but the efi inlet only has 1 outlet do i need to join the pipes together or blank 1 off?????
Old Oct 24, 2008 | 08:26 PM
Turbo-Beal's Avatar
Turbo-Beal
I cant be 100% shure but if i remember correctly the tee connetion on the main water pipe goes into one side of the oil cooler (so connect up the two pipes as you said) and the the other side of the oil cooler goes to the inlet manifold.
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
