Problems with heater, Ford Fiesta 2002 1.3 Finesse
Old Oct 23, 2008 | 12:05 PM
funktifeyeno's Avatar
funktifeyeno
Default Problems with heater, Ford Fiesta 2002 1.3 Finesse
Hi
I'm new to the forum.
Just looking for some advice.
The blower/fan for the hot/cold air has stopped working in my Fiesta, actuall so has the cigarette lighter. It's a 2002, 1.3 Finesse.
I've checked the fuses and they seem to be fine
Any ideas???
Thanks
Old Oct 23, 2008 | 12:11 PM
alan12112's Avatar
alan12112
Focus St mk2 310 bhp :D
Is is a mk6 fella or a mk5?
they made them both in 2002
Old Oct 23, 2008 | 12:15 PM
funktifeyeno
Old Oct 23, 2008 | 12:18 PM
funktifeyeno
It's defo the Mk 6, newer shape model
Old Oct 24, 2008 | 03:53 PM
alan12112's Avatar
alan12112
You can pop off the ciggy lighter mate by lifting up the panel it's on, it just pops up
check to see if the wire is connected underneath
heaters is a strange one as mine had never gone wrong...
You sure the fuse is ok? if it's just a blade fuse behind the glovebox might be worth while replacing it if it's only 20p for a new one
Old Nov 1, 2008 | 09:46 PM
cossie moon's Avatar
cossie moon
Durham RSOC member
hello mate the heating problem is a common fault as ive done loads of them at work! if u look under the boonet near the wiper motor there is a valve in 1 of the heater pipes going in to the heater matrix with a plug on ( two wires ) that valve will hav stopt workin but its a easy job to do and only 20 summit quid from ford plus vat! hope this helps!
Old Nov 1, 2008 | 10:18 PM
iansoutham's Avatar
iansoutham
OCD Victim
Didn't think the MK6 had that troublesome valve anymore, just the Ka, Fiesta '96-'02 and Puma?
Billy_RS
16
Oct 11, 2025 09:41 PM
Botts
Aug 13, 2015 04:16 PM
Bobby9779
Aug 11, 2015 06:47 PM
