turbo running lumpy please help
Old Oct 23, 2008 | 10:20 AM
tomanyturbos's Avatar
tomanyturbos
Default turbo running lumpy please help
hi all new to here and hope someone can help!!!
well here we go i just got another turbo but when i run it its sounds like its running on 3 pots and very lumpy
it idles fine without dieing but is very lumpy
ive checked compression and all pots are averaging 150psi
ive put new leads and plugs new dizzy new rotor arm
checked timing
4 brand new injectors but sounds exactly the same as when i started very fustrating
im sure its running on all four becase when i remove a lead fom a plug the engine starts to cut out and is the same on all four pots
does anyone have an idea wat else to check
all help will gratfully received!!!!
Old Oct 31, 2008 | 11:58 PM
rushty's Avatar
rushty
checked timing
hi m8 sounds like ya metering head to me
Old Nov 1, 2008 | 03:22 AM
Smartdj.'s Avatar
Smartdj.
oh no sounds like mines on it way out then....i have the sme problem it idles fine but as sooon as u rev it ...it runs lumpy but it has new everythingi thought it was somthing to do with fueling but not sure
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Churtz
15
Aug 13, 2015 06:40 PM
turbobill
Aug 9, 2015 05:21 PM
