Rev counter....
Old Oct 22, 2008 | 11:52 PM
ShandzS1's Avatar
ShandzS1
Default Rev counter....
Anyone running gotech and using the rpm output to run their rev-counter?
Ive got an after market rev-counter and also the gotech signal amp and still no joy!!
Old Oct 23, 2008 | 08:14 AM
Jamie Going's Avatar
Jamie Going
jam-sport.co.uk
we dont usually have any problems with them. you could always try taking a feed off one of the coil trigger wires directly to the back of the clocks.
Old Oct 26, 2008 | 05:15 PM
ShandzS1's Avatar
ShandzS1
yeah tried that and got half revs, as its a wasted spark sytem....
Does the gotech rpm output, be switched on/off??
Old Oct 27, 2008 | 08:32 PM
Bryan_RST's Avatar
Bryan_RST
Default rev counter
hi there i had this trouble when i had my gotech mfi pro fitted i could not get it to work so jam sport sent me the signal amp i wired it up like it said and it worked but it worked better when the car was moving but i did have to try two different clocks and wired mine to a permant live
Old Oct 28, 2008 | 09:49 PM
ShandzS1's Avatar
ShandzS1
What car/clocks did u use???
So u fed a constant +ve to the rev counter and amp, instead of a ignition +ve??
Old Nov 4, 2008 | 10:45 AM
ShandzS1's Avatar
ShandzS1
up
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
