Different ecu
Hi ,ive got an early s2 erst and the code is something like Blue,red,white. However without checking ive bought a chipped ecu and fuel ecu from ebay to replace it instead of having my one chipped. The one i bought from ebay is red,blue,black. Will it still work? Or if not can i take the chip out of that ecu and put it in my ecu?
yeah im pretty sure from what iv read, thats fine. only an issue if u have a knock sensor fitted loom, n the ecu requires a knock sensor, and u leave it unplugged
the s2 ecu doesnt require a knock sensor, and thats why some people favour fitting them
Just to clear this up for you all!
Every ECU will work on every rs turbo including hearts and diamonds!!
No mods needed unless you are putting a S1 Fuelling ECU on a S2 then the TPS needs rewiring or it will not work.
The knock sensor does NOT need to be plugged in and only came fitted to the later S2's, many of us unplug it because after so many years its got oversensitive and ends up retarding your timing cos it thinks your detonating when your not!
This i know form my own experience
but surely if the loom has a knock sensor, and the ecu runs in conjunction with said knock sensor, unplugging it will give u the same sort of results as disconnecting any engine sensor, engine goes into limp mode, retards ignition, n runs like a bag of wank?
fine if u run an definite early spec ecu, otherwise, thats surely a problem
Ignition ECU (silver) =
The det sensor is best removed off the engine, and put out of the way, but still connected,
as disconnecting it, can cause retarded timing.
If a knock sensor ecu is fitted to a no knock sensor engine/loom, best wire in a det sensor at the ecu plug (pins 9 and 10), and fit a sensor out of the way.
S1 85 spec is Blue red Blue.
S2 86 spec is Blue red white. As above, but now with knock sensor and 2nd temp sensor
S2 88 spec is Blue red black. As above but with low octane adjustment and knock threshold adjustment
S2 90 spec is Hearts hash diamonds.
Fuel ecu (black) =
Wiring needs sorting for the TPS , you need to bridge two of the S1 fuel ecu's terminals, as the the S1 ECU expects the TPS to earth through itself, where as on an S2 it is grounded to chassis earth.
S1 = blue code, hasn't got a rev limitor,
S2 = green code, has got one.
Fuel ecu (black) =
So what will i need to do. The colours match my ecu except the chipped one is black at the end and mine is blue. Mine has a green sensor disconnected which i believe is the knock sensor but i have nowehere on my manifold to put it so its discon.The car hasnt been messed with,is completely original as previously only 1 owner,my nan.Everything original.
The ecu will fit straight on, but needs setting up to the settings of the manufacture of the chip.
Best connect the (green sensor and plug) knock sensor to the loom and tie up near the ecu, and plug the manifold with the correct fitting. (dont need doing).
Block the hole off, using the correct thread plug union, or a spare sensor.
Somethings not standard then.
either someone has already pluged the manifold and removed the sensor, or you have a S1 manifold fitted.
What colour marking is on the stickers on both fuel ECU's?
I know the car is standard as it was my nans car from brand new and now ive bought it. Its an early s2 so maybe got a s1 manifold on it.On the inlet manifold on the rhs is the connection to the brake servo (?) and normally below that is where the green plug plugs into(?) BUT on my manifold under the brake servo connection there is nothing. Its cast that way. Id take a pic if i had the car here.
my car also has the same inlet, definitely S2 as it isnt the 2 piece S1 style, and it looks identical to a normal S2 inlet, except it has no knock sensor, and the inlet doesnt even have a boss cast there, its just non existent
as to what age etc, i couldnt say, as mine is a converted 1.3 pop, but all i know is the inlet is 100% S2, just pre knock sensor.
saying that though, my loom came from the same car, and the loom also has no knock sensor connection, thus why i didnt have an issue leaving it unattached
Thats a pre 86 S2 inlet
But as his has a 86 ECU, either
the ECU and loom have been changed from a pre86 to a 86 setup
OR
the inlet has been changed from a 86 to a pre86 S2 inlet.
OR
s1 blue red blue ecu no knock sensor
early s2 came with no knock sensor they ran the blue red white ecu
s2 88 spec came with blue red black ecu and a knock sensor
s2 90 spec came with hearts diamonds hash ecu and a knock sensor and could run slightly more boost than the others as std
SO sm - i have a early s2 ecu at the mo. I have a green conenction on my loom but no sensor to plug this into.
From your diagram I have bought a 88spec chipped ecu and fuel ecu to go with it.
Can i just unplug my ecu and plug the chipped ecu in?
Does anyone know if superchips just took the boost cut off or does it adjust fuel as well? And what boost to run at? Im thinking about 15psi.
Yes you can just plug it in!!!!!! LOL
Boost cut should be removed yes.
No fuelling is not adjusted, this MUST be done on the RR by a tuner.
Do not turn the boost up without the fuelling being set at the same time or you will go bang!
what year was the s2 made? that is deffo a early s2 inlet manifold, the s1 inlet manifold is 2 peice and that one is clearly not, there are 2 possibilites i can think of as to why u have a non knock sensor inlet manifold and ecu but have a knock sensor connector
1. the original engine has been replaced with a earlier one and the early inlet has been left on and the earlier ecu has been used too
2. the loom has been changed
now if the car is a late 87 early 88 model then more than likely its had a engine and ecu swap
if its a 86/ early 87 car then its likely to of had a new loom for some reason
personally id just buy a knock sensor inlet for £20 fit it with ur new red blue black chipped ecu and hey presto all is good
The car has had no new loom OR new engine. It is an early 87 model and is COMPLETELY original!!!
I know the car was stolen a few yrs back but only the ignition and door lock was damaged so cant see the engine loom being replaced just for that.
i'm sure Knock sensor setup was brought in late 86.
So your saying your got a
87 car,
86-88 ECU,
S2 inlet with no knocksensor bose,
Loom with a Knock sensor plug
87 car,
86-88 ECU,
sorry but if the car has the knock sensor wiring but no place to plug it then its not original, i cant see ford letting it leave the factory like this, so ethier its had another inlet and ecu or a new loom
put up pics of ur inlet manifold and pics of the sensor connection so we can make sure we are looking at the right things
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
Sep 14, 2015 09:04 PM
