2wd Cams into a 4x4
Old Oct 22, 2008 | 07:28 PM
kaisersolsay's Avatar
kaisersolsay
Default 2wd Cams into a 4x4
Hi guys,
Will cams from a 2wd engine fit into a 4x4 head ok?
Old Oct 22, 2008 | 07:45 PM
bigjim172000's Avatar
bigjim172000
Me Cossie Runs Atlast!!!!
I think to fit 4wd cams into a 2wd you need to use spacers, so my answer is No. On the basis you would need to have the cams or head modified to allow the bigger cams in. Might have got that the wrong way round of course
Old Oct 22, 2008 | 09:32 PM
kaisersolsay
Yeah, I have a 4x4 but have the chance and a pair of BD10's from a 2wd....will they fit?
Also, will rear braided hoses from a 2wd fit my 4x4??
Old Oct 22, 2008 | 09:54 PM
bigjim172000
Personally, i would say No. Unless you had the cams taken to a machine shop and modified. Not sure on the braided hoses. Cant see why not though
Old Oct 22, 2008 | 09:59 PM
AndyPen's Avatar
AndyPen
Isn't the only difference at the back end the thickness of the disc and the corresponding carrier width? Should be fine hose wise I'd imagine.
Old Oct 22, 2008 | 10:17 PM
bigjim172000
Im not sure, BUT i do know, to fit 4x4 cams into a 2wd head you need spacers to take up the extra room, soooo that means 2wd cams are too big for a 4wd head so would need machining down
Old Oct 23, 2008 | 03:02 PM
2001ode's Avatar
2001ode
For your help.
Claude
Old Oct 23, 2008 | 04:15 PM
kaisersolsay
Excellent diagram 2001ode....I think I will just look for a set of proper 4x4 cams!
Cheers guys
BRAMMER
15
Sep 14, 2015 08:52 PM
Chopshop85
Sep 12, 2015 06:42 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
rog
Sep 4, 2015 07:24 AM
