16" Wheels & 330mm Discs
Oct 22, 2008 | 03:53 PM
Do 16" comp take 330m discs?
If so does anyone have the internal measurement of the wheel for comparison against my 16" wheel.
Ryan
Oct 22, 2008 | 03:56 PM
Don't think they do ryan, thought you could bearly get 330's behind 17's
Maybe more space cos they are comps but i'm not 100%
I have 300's behind my 16's and they are a squeeze
Oct 22, 2008 | 03:57 PM
Plus if the wheels was 16" that would be 400mm so thats 70mm for rim and caliper space, it's fucking close whatever!!
Oct 22, 2008 | 03:58 PM
330mm discs are a squeeze under 17" comps mate......defo wont do under 16s!
Edited to add pic...
See - 330mm discs & 17" Comps!!
Oct 22, 2008 | 04:01 PM
thats a 16" wheel with a 330m disc behind them
just need to shave a small bit off the calliper thou, nothing major
Oct 22, 2008 | 04:04 PM
hmmm
right then, might have to be 305mm then
Oct 22, 2008 | 04:05 PM
Whats Christian got under his 16" ??
Oct 22, 2008 | 04:07 PM
Im going for 304 hopefully under 15s...
Your car is light your not going to neeed huge brakes !
Oct 22, 2008 | 04:18 PM
yeah think it may be overkil, but unsure if these calipers will go down to 305mm, as they were designed for 330'. but maybe just a pad change will sort it, if not i might have to sell them on.
Oct 22, 2008 | 04:19 PM
Oct 22, 2008 | 04:21 PM
Oct 22, 2008 | 04:27 PM
Ive got 325mm discs with High Spec Calipers behind my 7 x 16 Comp MO's
Ive lowered the front a bit since this photo before anyone mentions it.
Oct 22, 2008 | 05:14 PM
There may be hope yet then, luke there brembo's, that's all you need to know
Oct 22, 2008 | 05:26 PM
i've had 308's behind 16's in the past.
Oct 23, 2008 | 06:57 AM
i dont care about 17's
Oct 23, 2008 | 07:08 AM
Quote:
Originally Posted by
Ryan
Ryan
LOL
bet you wish YOU had these wheels
Oct 23, 2008 | 07:13 AM
jesus, how much is that lot worth?
Oct 23, 2008 | 08:04 AM
All depends which Comp wheel your fitting Ryan
Oct 23, 2008 | 08:06 AM
im not fitting a comp wheel, im want an internal measurment from a 16" compomotive wheel for comparison to my wheels
Oct 23, 2008 | 08:11 AM
why do i want that?
does that tell me an internal mesurement of a comp 16"
Oct 23, 2008 | 08:39 AM
I ran 16"s on my last track S2, both compomotive TH2 and Superleggera. The 315mm AP 4 pot kit was close against the OZ's but there was a good 10mm clearance on the Comps.
Oct 23, 2008 | 08:45 AM
All im saying is each compomotive wheel wheteher 14-15-16-17 is different between the dismensions.
My cxs wheels in 15" offer more clearence than a 15" MO
Best way will be to fit your wheel on a car with the size brakes you want.
Anyway why you want 16's ,15s is the way forward!!!
Oct 23, 2008 | 08:49 AM
Ryan,
I have no idea what inside dimensions the 16 Comp Mo wheel is, but I can assure you, you can fit 330s and AP 4-pots (calliper dependent), as I know of several who have done it.
Oct 23, 2008 | 08:55 AM
cheers mike, thats what i wanted to know, im pretty sure i will be able to squeeze 330's under there, as they run 305mm as standard under them.
luke, 15's will be an option if i decide to run smaller brakes, but there arent that many wheels i like in 15's that suit my car.
16x8's go on nicely though with some KW V3's
Oct 23, 2008 | 08:56 AM
Have you posted what car youve got yet ryan?? Mk1 Golf??
Oct 23, 2008 | 08:57 AM
yes mk1 golf max, and no i havent really.
GTI non sunroof.
will be running seat sport engine and 6 speed box with peloguin diff. (about 280hp in current guise) cant be arsed with more than that, as thats a standard drop in package, that works and works well, could obviously go well over 300, but that in a 850kg will be just silly.
Oct 23, 2008 | 08:58 AM
What colour and model have you got
Oct 23, 2008 | 09:08 AM
Charlie Chalk
AP 330's under his 16's...
Oct 23, 2008 | 09:17 AM
Ryan - did you know you can turbo a standard VR6 engine, run a decomp plate, whack a GT3076 turbo on it (at the very least), get a piggy back chip on STANDARD management & different injectors and easily run a reliable 400/400!!!
Oct 23, 2008 | 09:32 AM
yes lee i did mate, seen quite a few done on the forums and was very suprised.
also whats more suprising is the vr6 engine goes for like £300 second hand.
400/400 engine for about 1.5k
think it would make the mk1 very front end heavy though.
Oct 23, 2008 | 09:36 AM
Mad init - I saw one at the rolling road day I went to on Saturday - made 430bhp/440ftlb lol - surprised wasnt the word - all home built - very very impressive!!
Oct 23, 2008 | 09:42 AM
i know of a twin engined twin turbo'd mk2, running 2 of those engine.
supposedly between 800-900hp
cant imagine the speed of that thing
Oct 23, 2008 | 09:47 AM
I have 328mm dia disc's with AP 5820 6 pots under 16" image wheels.
No pics as I am a work.
Brian
Oct 31, 2008 | 03:28 PM
Sorry to drag an old topic back up, does anyone know if 325 mils will fit behind escort cossie wheels?
Has anyone done this?
Namely these bad boys
http://www.pumabuild.co.uk/catalog/p...a552b650d4a816
Thanks
Oct 31, 2008 | 03:45 PM
alan12112
Yes and no they won't.
Even 304mm with big callipers won't fit.
310mm discs and standard callipers is the limit of the standard wheels (on a 4x4 car, you may get bigger on a 2wd).
Oct 31, 2008 | 03:52 PM
Fuck!
Looks like I need to sell the cossies then!!
Oct 31, 2008 | 06:07 PM
Mike Rainbird
Ryan,
Here's 330s under a 16" MO on a Sunny Gtir. I think he had to use a 3mm spacer.
Oct 31, 2008 | 07:51 PM
Lee_R21Turbo
not a definative answer there because of the calipers your using,ie not motorsport ones,with the correct caliper a 330mm ap set up will fit under 16's,355's will fit under 17".
Oct 31, 2008 | 07:52 PM
Mike Rainbird
i had 309mm tarox kit with 6pots, which were designed to fit on escos, under std wheels
Oct 31, 2008 | 07:53 PM
Fast Guy
now that is because its using a proper caliper.
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
rsturbo27
Sep 5, 2015 05:08 PM
