timing belt change problem
Old Oct 22, 2008 | 03:42 PM
mk2rstaff's Avatar
mk2rstaff
Question timing belt change problem
just tried to get the bottom pulley off and it seemed to jump the teeth on the belt when i turned it, i had a locking bar through the cam pulley to try and hold it but the bottom pulley kept spinning, any other way to get the bugger off please???
Old Oct 22, 2008 | 03:45 PM
cozmeister's Avatar
cozmeister
More boost Igor!
To get the crank pulley bolt out, get someone to sit in the car, with their foot hard on the brakes, and put it in fourth. Use a suitable bar and socket and undo the bolt. It'll be effing tight but will turn quite easily after it's cracked.
Use the same trick to do it up again.
Old Oct 22, 2008 | 03:52 PM
mk2rstaff's Avatar
mk2rstaff
small problem there the gearbox is fooked and i have taken the stick off, will put it back in though and try it, i will ram it in gear some how lol, cheers cozmeister
Old Oct 22, 2008 | 09:21 PM
If you can put a long extension on a socket and get a good whack with a hammer on the extension the shock will loosen it, this is how I did mine, and for tightening just applied handbrake in gear(5th) and it went up to poundage no problem.
RUBY123
Oct 22, 2023 12:04 PM
cos elle
Sep 1, 2015 06:48 PM
taylora1409
Aug 12, 2015 12:06 PM
Sjieter
Aug 5, 2015 09:47 PM
