Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
throttle bodies and ecu for zetec
Old Oct 22, 2008 | 02:41 PM
JPA's Avatar
JPA
Default throttle bodies and ecu for zetec
as above , may consider bike ones also any other zetec tunning parts , cams , 4 branch etc
car is fiesta mk3 , 2.0 silver top
W. H .Y
john
07770927234
Old Oct 22, 2008 | 06:26 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
i have a set of gsxr thorttle bodies already on a zetec manifold all ready to go straight on Ł350 posted all ready to go
Old Oct 22, 2008 | 07:13 PM
JPA's Avatar
JPA
hi mate , might be intrested in these , have they been run on the car ? and jetted to suit 2.0
do they come with all fittings req'd , wiring etc , and what ecu did you run with them ?
could pm me your number if thats easier
cheers
john
Old Oct 22, 2008 | 09:30 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You don't 'jet' throttlebodies......
Old Oct 22, 2008 | 09:35 PM
Roosie's Avatar
Roosie
like said you dont jet them i was going to run emerald on them but you can run any type all you need to do is put a hose on for fuel feed and return and then get it setup.
Old Oct 22, 2008 | 10:02 PM
JPA's Avatar
JPA
just noticed i wrote that , ment to say what size injectors , or is it still the bike ones fitted
and so will they work on standard ecu if i make the tps fit ?
john
Old Oct 23, 2008 | 02:30 PM
Roosie's Avatar
Roosie
as far as im aware you can fit them to std the injectors are good enough to flow upto around 200bhp
Old Oct 25, 2008 | 06:06 PM
JPA's Avatar
JPA
anything ?
Old Nov 7, 2008 | 03:18 PM
JPA's Avatar
JPA
pm sent
john
Old Nov 7, 2008 | 03:39 PM
Sunil_FiestaRS1800's Avatar
Sunil_FiestaRS1800
I might be selling my raceline spec 2.0 engine, Racline head and matched cams, high comp, uprated valve springs for higher revs. Also got full exhaust system including four branch and de cat, cossie front brakes, CTS stg 2 gearbox with quiafe diff, b&m shifter, and load of other bits
Old Nov 7, 2008 | 05:29 PM
CCassidy's Avatar
CCassidy
I'm selling my full WeberAlpha setup:
https://passionford.com/forum/ford-non-rs-xr-st-parts-for-sale/266126-sold.html
Old Nov 8, 2008 | 12:41 AM
JPA's Avatar
JPA
pm sent
Old Nov 17, 2008 | 12:31 PM
JPA's Avatar
JPA
ROOSIE , REF: GSXR THROTTLE BODIES
can you get in touch mate if these are still for sale ? Pm'd you a couple of times , i'm looking to buy them
cheers
john
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
JK12
33
Apr 26, 2021 12:09 PM
TPM961
Jan 15, 2018 10:50 AM
dombanks
Sep 21, 2015 08:38 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
